Question about Akai VRD974 DVD Player / VCR Combo
Can i record from my hi-def samsung flat screen??what do i need to do??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Akai Master
  • 1,745 Answers
What do you mean by "record from flat screen"?
Posted on Mar 30, 2015
Best quality USB multimedia playback format for the neoniq 21.5" tv
mpeg 4 is Hi def. If you record 1080p then it will play back in Hi def.
Apr 20, 2013 | Sharp Aquos Televison & Video
Mode not supported message
ok there should be be a setting in the menu probably called video source depends on what model it is, make sure you put it on hdmi,this should do it, let me know if it helps
Apr 18, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Can get analog stations recorded but not hi defination
Hi, unless the VCR/dvd recorder is hi def then you won't be able to.
Hdmi connection is hi-def, I think you can have a hi-def signal through composite, but it's your recorder thats the problem, it cannot read the number of line a hi-def signal has.
I have just found this.
http://www.brighthub.com/electronics/home-theater/articles/48499.aspx
I hope this helps.
Regards - Anthony
Feb 09, 2010 | Toshiba Televison & Video
Band of dot's(millions) across screen only whilst watching in hd mode and whilst using any menu option such as volume etc. dot's not there whilst watching any sd programes
I think I have a good idea of what you're experiencing.
Our minds are so set in the low-def mode that when those extra lines are filled in for high-def it looks like a bunch of dots. Notice everything is so much more clear? I thought the same thing when I watched my first blu-ray disc.
Watch something in high-def and then go back to standard immediately after. You'll notice that you can't get near as much detail off of the low-def.
Those dots are your mind trying to put high-def into low def.
Hope this helps; please rate my solution accordingly
Respectfully,
Don
Feb 05, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Sony LCD cutting off image when hi-def cable hooked up.
This will happen invariably. Depends on the nature of the signal that is being received. Some will fill entire screen, others will not.
Just go with the flow - tv is operating normally.
Aug 23, 2017 | Sony WEGA KD-34XBR970 34" TV
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
TV / DVD Recorder HDMI issue
By default most HDMI DVD players are set to produce their picture output on the Scart connection. This allows configuration of the device on all TVs.
However your manual should tell you (Probably in techno speak) what you need to do so switch it to HDMI mode.
I don;t have a copy but I am searching for it on the net. If I find out how I will let you know.
Mar 13, 2008 | Televison & Video
Using the Misubishi HS-HD2000U
The connection "chain" that you need to have set up is as follows: First the source goes to the HD VCR, then that output goes to the TV...accordianman
Feb 13, 2008 | Mitsubishi HS-HD2000U VCR
DVD-R120 high def recording???
No, it will not. It is not a hi definition recorder.
Oct 18, 2007 | Samsung DVDR120 DVD Recorder
Akai VRD974 DVD Player / VCR Combo Logo
48 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
