Question about Refrigerators
My Refrigerator has not made ice since house water was turned off for 3 hours and turned back on, how can i fix?
Has not made ice since house water was turned off for 3 hours and turned back on
  • Refrigerators Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) You may want to reboot your ice maker. You did not provide a model number so I can not tell you how to do this. Your model number is on a label on the inside wall, near the top, in your fresh food section.
2.) Is the water flow from you water dispenser slow? If so you may have a plugged up water supply shut off valve to your refrigerator.
When the water was turned off and then back on, the valve seating material may have broken free.
You need 65 PSI water pressure to the ice maker.
Turn off the water valve. Disconnect the water line at the solenoid valves. Have a bucket and towels ready.
After disconnecting and the valve shut off, is water still coming out?
Ok, with the water supply ling in the buck slowly open the water valve. Are you getting good pressure?
You may have a frozen fill tube to your icemaker.
You may also have a plugged up filter screen in your ice maker solenoid valve.
But I think you have a water supply problem at the valve.
Posted on Mar 30, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,745 Answers
Disconnect (or turn off) the freezer; also disconnect water supply. Keep that for a day to unfreeze water pipes inside then reconnect.
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
Ice maker quit working on side by side whirlpool refrigerator
Good day,
It is important that the temperature is at or very near normal. Anything above 10 degrees will slow if not stop ice production. That is controlled by a thermostat embedded in the ice maker.
If the temperature is normal then proceed with this trouble shooting guide. It should solve your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Oct 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
May 25, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker makes about 8 cubes every 3 hours. That is pretty darn slow. Is there someway to increase production speed. This is a brand new refrigerator
The best way to deal with this issue is to use a step by step trouble shooting procedure, and in your case paying special attention to the line supplying water to the machine including all fittings. May be a bad water connection problem.
Apr 15, 2010 | Frigidaire FRT18B5J Top Freezer...
My ice maker has stopped making ice. We had to shut down the main water valve to the house and after returning the water to the house is when the ice maker stopped working. We have established that water...
Good day,
For all reasons it is best to do a step by step procedure to get the ice maker up and running.
Apr 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Stopped making ice
Good day,
There are a lot of reasons they will quit making ice. The best way to check it is a step by step procedure. The freezer must be at normal temperature to perform the tests.
Apr 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Side by side refrigerator,ice maker not getting water.water dispenser in door still working.What's up?
Good day,
The best way to get it up and running is to follow a step by step proceedure. Ignore any steps already performed.
Mar 05, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrigerator 59562990 icemaker worked then stopped
Good day,
Could be air, but if 48 hours passes without ice, it's not the problem.
To trouble shoot the ice maker, it is best to follow a step by step testing procedure. Ignore any step that does not apply.
Feb 17, 2010 | Kenmore Refrigerators
I have a whirlpool side by side refrigerator and the ice maker is not making ice. Apparently the water is not getting into they tray that makes the ice. Should i turn it off and wait for it to defrost??
Good day,
That might help, but it is better to follow a step by step process to solve the problem. Your solution, in a way is part of the process that follows.
Feb 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Refrigerators Logo
190 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
