Question about Ariens Zoom 42 In 165 HP Briggs Stratton Zero Turn Riding Mower ()
Battery will not hold a charge. i charge it or jump it off and it will be dead the next time I use it. I even bought a new batter and it was drained when I went to use it again
    Sergeant:
  • 417 Answers
My guess is the key switch is bad and is staying energized when it should be off. Or you're just leaving it in the on position which is common as well. Not a lot of things to drain on a lawn tractor without being aware of it, ie; smoking ignition solenoid or headlights staying on or the starter running continually. If your stator (alternator) was bad, it would drain the battery when running because the machine wouldn't run of the power produced by it, it would run off the stored power in the battery itself, the battery is merely there to initially start the engine and act as a radiator overflow would in a car.
Posted on Apr 04, 2015
    Top Expert:
  • Ariens Master
  • 12,957 Answers
If a new battery is not holding a charge after a week, then there is a drain on the electrical system when the ignition key is removed.
To confirm this hook up an ammeter to the battery, remove the key, make sure everything is turned off and check the meter. It should show a zero output. Any indication means that current is leaving the battery and that condition will over a period of time discharge the battery. Till you locate the problem, disconnect the battery immediately after use after having made sure that your electrical system charged the battery while you were using it. U have to locate the source of the leak because lead acid battery packs are not tolerant of deep discharges - they will prematurely kill the battery.
Posted on Apr 03, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
You can get a cheap DVOM from Harbor Freight for around ten bucks. Set it on DC Volts and check the battery voltage after its charged WITHOUT the motor running. Then start the mower and check the battery voltage while it IS running. If the alternator is putting out, the voltage will go UP. If its not putting out voltage, the battery voltage with be the same as when the mower is not running.
Your problem lies withing the charging circuit if the voltage does NOT go up. If it does go up but the battery is still dead the next time you get it out, take the + terminal OFF as soon as you finish mowing. Put it back on next week when you need to mow again, and if it is still charged....you have a drain in the electrical system and the real fun begins as it is discharging through a ground draining the battery.
You could also have a bad cell in the battery as they have a tendency to sulphate up over the winter without the use of a 'battery tender' whose job it is to 'top off' the battery continually and as a result keeps the battery 'de-sulphated' during periods of non-use.
An auto parts store should be able to bench test the battery to tell you if its good or not.
If you choose to use a battery tender it is important to utilize one that is a " floating charger " and not one that has a steady output. They also will not charge a dead battery, they are used to 'maintain' voltage on a fully charged battery.
Posted on Apr 01, 2015
    Problem Solver:
  • 9 Answers
It sounds like it has a short on it or the alternator isn't giving a charge. check the wiring for breaks... charge the battery up and get a altmeter to test if when running the battery is getting a charge, hope this helps
Posted on Mar 30, 2015
How do I test the starter (Denso DB5B6) on a Honda GX340 11.0 engine?
IF you take it out and go to autozone or orielly etc they have a machine that can test it
Jan 13, 2015 | Honda Cars & Trucks
Battery keeps losing charge in y 2001camry after only about 5 days
A voltage drain in 5 days should be serious enough to find, unless it is at random times. The drain could be on and off every other hour for example.
You may have to check the battery voltage level each day with one fuse pulled to see if the voltage level drops. If the battery has been tested and it is in good condition, it should hold a charge for at least a couple of weeks or longer.
Feb 21, 2013 | 2001 Toyota Camry
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
Battery is dead. It can be jumped, but won't hold the charge if you shut the car off. 2008 Chevy Impala ltz. We were on the road and stopped for a overnight stay. When we got ready to leave the next...
Battery is shot, buy a new one (possibly get some warranty credit if it is new enough). I just had a co worker ask me about the same problem today and the dealer replaced his battery in his Jeep. The new maintenance free batteries only last approximately 5 years and they don't give you a heads up like they use to in the old days. I have started cars in the morning and noticed that they start a little hard that day. The next time I try to start it, the battery is dead.
Back in the day, I think we had a little more warning because we had to crank the engines longer. With the electronic ignition and fuel injection the modern engines crank so easy, so we don't put a lot of strain on the batteries and when they go they go.
Nov 08, 2011 | 2008 Chevrolet Impala
Battery dead, jumped car, started but had to keep the gas on or car would kill...replaced batter just a few months ago
check your alternator its what keeps battery charged if the alt is defective it will not charge battery draining it fast..
Mar 07, 2010 | 1997 Jeep Cherokee Country
Batter won't stay up after jumping it off
Take the battery to an auto parts store and have them test it, most do this for free. If you can, take the alternator with you. If your able to keep the car running after the jump, try to drive it to the auotparts store for the testing.
Aug 07, 2009 | 1998 Volvo V70
After charging baterry doesn't hold charge more than 20 minutes.
depending how old your laptop is the batter is on its last leg. What happens is if you leave your laptop plugged in all the time, the batter gets overcharged and begins to die. For the next battery you acquire remember to charge it for its required time then drain it out by using the laptop. This will prolong the life of the battery.
May 25, 2009 | Acer Aspire 5100-5033 Notebook
Dead battery or alternator?
Sounds as if the alternator is shot.
You can take the battery and alternator in to any parts store NAPA, AutoZone, Murrays, etc. to have it load tested for free.
Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 31, 2009 | 1990 Dodge Spirit
Ariens Zoom 42 In 165 HP Briggs  Stratton Zero Turn Riding Mower () Logo
221 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
