Question about Brother Sewing Machines
Hello I have brother sewing matchine XL 2600i . and i didnt set anything its just as i bought it and the needle is locked and facing in an incorrect direction to the footer hole. i dont kbow how to fix that. can you please tell me how i can set the needle straight to the matchine. thank you Thanks
  • Brother Master
  • 12,467 Answers
If you bought it new and doesn't work, take it back. Sounds like it may be defective.
Posted on Mar 30, 2015
    Master:
  • Brother Master
  • 470 Answers
Best to take it in and have a Service done. You MAY have a junk machine, and how money do you want to spend on it?
  • 1 more comment
  • Anonymous Mar 30, 2015
    is it that bad? i dont know how much its gona cost me.
  • William Gilbert Mar 30, 2015
    Many repair shops will tell you for free that most old machines ar not worth a $20 cost estimate.
    i see .okey but mine is brand new.
SewTechWayne
  • 186 Answers
SOURCE: Brother xl-2600I sewing machine thread problem
Try turning the handwheel so the take up lever is at its top position, then remove the garmet.
good luck!
Posted on Jul 30, 2009
SOURCE: Hello I have an old Riccar 6800 sewing machine
Hiya, the threading for this machine is pretty standard so you won't be going wrong there. Have you used a sewing machine before? The tension dial (on the extreme left) should be set at 5. The other dial to your left should be on blue zigzag with orange broken line. The dial on the right should be set at 0 and the bottom one on 2 - 3. I've been looking for a manual for this machine as I inherited this one. It took me ages to suss straight sewing out. Another thought is take it to a repairer and ask for a quote. Good luck.
Posted on Nov 23, 2009
  • 36 Answers
SOURCE: Brother XL--2600 Sewing Machine not picking up Stitches at all!
Take the thread out, Take the needle plate out Watch as the needle comes comes down, make sure the hook is just above the eye of the the needle as it makes its pass by the scarf of the needle if not refer to my post on timing.
Posted on Jun 02, 2010
  • 1788 Answers
SOURCE: learn how to change the needle in my brother xl
If, you do not have the manual, please go to Brother.com and download one for free. Also, to change your needle without a screwdriver, use a nickel or dime. Sometimes that works better than a screwdriver and won't strip your screw head.
Posted on Jul 26, 2010
  • 223 Answers
SOURCE: Brother XL 3027 sewing machine the needle hit the
That's ok, needles get bent all the time and sometimes broken too. Just give it a new needle (look on the shaft at the top of the needle, you should see a screw to loosen for removing the needle). Note that the needle is made with a flat side on the shank to locate it properly, watch how the bent one is positioned when you remove it.
lp
Posted on Dec 27, 2010
Brother xl 2600 needle hitting feed dogs
Could be several reasons! Check that your needle is not bent, Make sure that you are using the needle is the needle size required BT specific machine. Make sure timing is checked by ttechnician.
Jul 05, 2014 | Brother XL-2600I
I just bought a brand new Brother XL 2600I and it was working great for the first day , next morning i change the thread to actually sew not just test strips . I keep getting bunches of thread or if i
Most likely your top thread is not threaded correctly. Unthread and rethread. Check with your manual to make sure you have threaded correctly. Thread bunching up on bottom indicates top thread is threaded wrongly.
Mar 05, 2014 | Brother XL-2600I
Brother XL-2600i upper tension too tight even when set to ZERO
I agree with you to take it back & buy another brand
Sep 30, 2012 | Brother XL-2600
I want to look at a manual for a brother XL=2600i sewing machine
Here you go, from the Brother website
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl2600i2610eus&dlid=&flang=English&type2=-1
Oct 10, 2011 | Brother XL-2600I
Learn how to change the needle in my brother xl 2600i sewing machine
Jul 24, 2010 | Brother XL-2600I
HI, my brother xl-2600i is hitting the metal on the bottom not going through to the bobbin. don't know what to adjust. help! thanks in advance.
First, check to ensure your needle is not bent. If its not bent then just adjust your metal plate at the bottom. Loosen the screws and shift the plate back, tighten the back screw first and see if the needle now passes the plate. If not make some more adjustments. Once the needle passes the plate properly, tighten the front screw. Hope that helps.
Apr 13, 2010 | Brother XL-2600I
good luck!
Jul 30, 2009 | Sewing Machines
Machine makes banging noise
wow, taking apart and putting it back together is a big feat. I think you should check the needle and its height, could be to low and is hitting just enough to make noise and not break.
Jul 24, 2017 | Brother XL-2600I
Sewing Machines Logo
37 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
