Question about Homelite Garden
HB 100 kill switch does not shut engine off. What should I be looking for in terms of troubleshooting.
  • Homelite Master
  • 1,169 Answers
If it is oof the rocker sytle switch the contacts are probably dirty and need cleaning. Unless you are experience in servicing these switches it would best to just replace it.
Also ignition coil do go bad and can cause this too. To test for this just use a length attached to coil terminal. Start the engine and ground the wire if the engine shuts then coil is fine.
Posted on Apr 01, 2015
How can I shut off the motor? Is there a kill switch?
there is supposed to be a kill switch on side of engine. just follow the cable down to engine. it may be broke or just frozen. the cable that shuts down mower. Good-Day!
Jun 07, 2014 | Garden
Engine would not start and now the battery is swollen
Hi check polarity of battery ,2 look at the wiring loom look for cable damage shorting burning ,3 I think its more than likely this , you need to ask why when you hit the kill switch did it not shut off ,4 check the rectifier , also ask did you get anything done fitted eg alarm lights ,to swell the batt then it had to get an unusually high charge in reverse please let me know how you got on
May 25, 2014 | 2006 Hyosung SF 50
Green Machine 4600lp blower wont shut off
As simple solution number one, I would recommend getting your trusty can of WD-40 out and spraying the whole throttle cable and ends. A possibility is that the throttle, when you go all the way to the lowest position, and is operating freely, is supposed to completely shut off the fuel to the engine. Simple solution number two is for you to look and see if there is, or supposed to be, a metal tab-looking thing that you push down to short out the ignition spark to the spark plug in order to kill the engine. These sometimes get broken off.
Nov 14, 2013 | Motorcycles
Dose not to strat can"t fine the kill switch
What kill switch ??
If the engine cranks but does not start, someone would need to figure out if you are missing spark to the plugs or fuel to the injectors to have a direction to troubleshoot.
Oct 08, 2012 | 2003 Kia Spectra
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Aug 12, 2009 | Garden
Kill switch on handle
I presume it is the throttle switch as well, as most of the mowers have the kill switch there.
the plastic throttle handle should have a round pin at one end which connects to the throttle cable, there is usually a plastic outer cover that is retained by a threaded screw which holds it all together on the handle,
there may be a small screw at the top of the plastic throttle cover which is the adjusting screw for the throttle cable, if you loosen it, pull the throttle lever right back and push the screw down until it stops and then tighten it that will adjust the cable and should shut the engine down when the lever is pulled right back
Apr 02, 2009 | Garden
Replaced stop switch and it still won't shut off!
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Jan 03, 2009 | Briggs Garden
Garden Logo
231 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
