Question about Pool & Spa
I need to replace the impeller for a pump 58113 where could i buy one
  • 1,631 Answers
Hi Joanne,
what is the make and model of this pump?
is it a pool pump, or an automotive water pump?
qui k Google search to find what you so generically asked found no pool pump with those numbers , but plenty of water pumps!
being specific, helps us here within the fixya forum to assist you better.
Posted on Mar 30, 2015
Testimonial: "Hi Mike It is out of a lay z spa egg. it is the water pump in the egg,The impeller has split."
  • joanne
    joanne Mar 30, 2015
  • Mike Tellegen Mar 31, 2015
    http://www.directaftersales.com/contact-... This a UK based company. No parts that I can see readily available domestically here in USA.. Seems odd, but had no luck. Try the link I posted. They might be of help?
Magnetek 7 187400 20 cleaner booster pump
if you need the impeller and volute you also need seals sounds like it ran without the filter pump on might be better buying a new pump when they get hot they distorte and will leak also PVC pipe is probably distorted youll have to replace the distorted pipe also
Jul 14, 2014 | Century Pool & Spa
Layz spa pump 58113 is very noisy can I replace the bearings or get a new part
If you are going to pay someone to replace the bearings, you may aswell pay the money to replace the motor and do a seal change
Mar 11, 2014 | Pool & Spa
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Maytag Neptune purchased brand new in 2007. Tumbler won't spin and water doesn't get pumped out, all I head is a humming noise coming from the water pump. I opened the back and could feel the water pump...
There is something jamming the impellers in the pump (coin, nail, bobby pin, ect.) You need to manually get the water out, remove the pump, and see if you can find and remove the obstruction. If you find something in the pump and remove it, check the impellers before you put the pump back in. There are 3 plastic impellers, make sure none of them broke off. If they did not break off, your good to go. If one or more broke off, you will need to replace the pump, you cannot buy just the impellers. good luck.
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
P2RAXYG-126L Pump
you will need to pull the front cover off the pump housing in order to inspect the impeller. It is possible that it has failed and just needs to be replaced.
Sep 02, 2008 | Home
Pool & Spa Logo
282 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
