Question about GE Refrigerators
WIRING CONNECTIONS FOR REP[LACEMENT PART DIFFER WITH NO MARKINGS
THE PRODIGY THERMOSTAT TR/86 223C3823P001 HAS THE ELECTRICAL CONNECTIONS ON THE RIGHT. RED - 1,TOP WHITE - P1,BOTTOM. THE REPLACEMENT PART GE WB20K10008 CONNECTIONS ARE ONE ON THE RIGHT AND ONE ON THE LEFT WITH NO MARKINGS. WHICH WIRE GOES WHERE?
  • GE Master
  • 473 Answers
I looked that part up and it seems to be a simple 2 wire thermostat. The heat turns it off at a certain temp. So the wiring doesn't matter which color goes where. The internal contact are either on or off depending on the temp. Just make sure the wire plugs don't touch any other metal when installed.
Posted on Mar 30, 2015
  • Rob-Joni Thurkettle
    Rob-Joni Thurkettle Mar 30, 2015
    You are correct Sir. I thought the same thing, and had everything connected and reassembled, but was hesitant to plug it in and try it for fear of shorting out a $100.00 thermostat. After you confirmed what I thought I gave it a try and the new ignitor and thermostat work perfectly. I thank you for you quick response as Ge never did respond after more than 48 hours.
  • Jerry Smith Mar 30, 2015
    Big companies do seem to have the time to respond. I was a road tech for GE for 25 years before I took a managers position for a smaller company. I'm semi retired now so I try to help on sites like this one.
2011fordf150 code po735
code p 0735 refers to gear 5---incorrect ratio===causes --wiring--TR sensor /switch---shift solenoid---transmission mechanical fault
if there are no abnormal noises or problems being experienced with the transmission
leave that as a cause to absolute last resort
wiring condition , connections not corroded , tight etc , first , then check the TR sensor /switch for operation
take it to an accredited auto transmission specialist shop for a proper diagnosis and quote
Oct 20, 2016 | Cars & Trucks
What are the probable causes of DTC P0706.
code p 0706 refers to transmission range (TR) sensor/switch--range /performance problem===causes---wiring---TR sensor /switch
check for clean contacts in the harness connections -replace the sensor
Jan 04, 2016 | 2002 Volkswagen Passat
Where is the lint screen on a GE prodigy profile top load washer?
most top loader flint collectors are in the top of the agitator where you put in the comforter fabric softener. Pull this section up and the lint sock will be at the bottom of it
Apr 01, 2013 | GE Profile Prodigy WPSE4200A
My DGS18LBR GE Refrig does not cool the top refrigerator, but the bottom freezer seem to be find. Is it the dual control unit?
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired to gather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care in solving the problem......
May 12, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
Hello. We just moved into a new home. The house came with a GE side by side (GSH25KGMCWW) refrigerator. The freezer works great! But the refrigerator is not cold; it's not even cool. Can anyone...
Hi,there
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
I hope this will in solving the problem....
May 08, 2011 | GE Refrigerators
Our GE Americana A3309AASAWW has stopped cooling in the refrigerator portion...the freezer still works properly...what could be the problem
Hi, Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section . Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function . Hope this help in solving the problem....
Oct 31, 2010 | GE Americana 15.6 Cu. Ft. Top-Freezer...
Ice forms on bottom of freezer and comes out on floor
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Hope find it helpful......
Jul 29, 2010 | GE CustomStyle 21.5 Cu. Ft. Side-by-Side...
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
