Question about Optoma DS316L DLP Projector
The picture we get is as if there is white spits on the screen, not dust. very bad around the edges. every thing else is in focus
  • 45 Answers
Hmm...check the screen? It might be dirty bulb or dirty mirror. That means you'd have to disassemble it ... unless its on warranty. If not, I suggest taking pictures of it as you take it apart.
Posted on Mar 30, 2015
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
No picture just white lines on left of screen
Check the antenna cable, also provide details on make and model.
Oct 24, 2008 | Televison & Video
Horizontal hold does not seem to work. horizontal lines in pic
hi,
Is there is white horizontal thine line on all over the screen then the screen voltage of you TV is high. Can be caused by bad base socket in the picture tube neck, faulty focus/screen block. Check the two things. You can see the base socket at the picture tube neck replace all the three base sockets for the three CRTs. if problem remains then you have to replace the focus/screen block. focus/screen block is one through which you can adjust the screen voltage and focus voltage. If the potentiometer in side it have some problem then this problem can occur. Have added the image for two items for your reference.
ok
Jun 09, 2011 | Mitsubishi WS-55807 TV
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
Pictures are blurred around the edges
Have you tried to change the settings like to scenery or adjusted for lighting that could have an effect. The only time it's blurry for me is when I don't adjust for the picture I am taking. The camera itself focuses so maybe there hasn't been enough time for it to focus. Try those things and if it doesn't work I would take it in to a camera shop maybe it has internal problems.
Sep 27, 2008 | Nikon Coolpix S51c Digital Camera
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Yellowing screen off-center - not a convergence issue
You might want to try the optic lens adjustment screw on the side of each crt. Mark them before moving.
May 30, 2007 | Philips Magnavox 51MP392H Rear Projection...
Sony KP 48S75 Rear Projection Red Haze around objects on screen
Sometimes this can be caused by excessive dust buildup on the lens over the red picture tube, and if you have access to that part of the set, that is where I would start. If it is clean, then you could have the red tube out of focus either due to a bad focus block or if you were lucky, a minor adjustment may fix it. If the set was over 8 years old, I'd consider replacing it with a HDTV model. Check out Consumer Reports latest issue for a start.
Dec 16, 2006 | Sony KP48V85GRAY 48" Rear Projection...
Optoma DS316L DLP Projector Logo
110 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
