Question about Kyocera Mita Ecosys FS-1320D - 37 PPM Monochrome Duplex Laser Printer, FS1320D, 1102LZ2US0
Ip address for kyocera fs-1320d
Want to connect it but asking me ip address
  • 890 Answers
Contact your IP Provider for the information you require
Posted on Mar 30, 2015
I need to add an IP address to a Kocera 1320d that has been hooked up as a USB printer, how do i do this?
You can print a status page by pressing for 5 seconds the green button and see what IP address has the printer. Then you can modify it through your PC. The most important is that you have a NIC (network interfade card), because this printer (FS-1320D) comes from Kyocera without a NIC. Unless your printer is already intergrated with a NIC.
Aug 21, 2014 | Kyocera FS-1320D
Kyocera printer hookup to iMac using Ethernet connection
check the network printing settings in the printer, its a problem in the settings somewhere, unless theres a fault somewhere.
Jul 24, 2008 | Kyocera Mita FS 3800 Laser Printer
How to set ip address for kyocera 1320d
Print a Status Page by pressing the green button for about 5 secs. Check the IP Address on the Status Page. If the IP Address is similar to your local network, you type that IP Address in an internet browser to open the Command Center (web interface).
If it is not similar, then you can change PC's IP to be similar to printer and via the command center, you change the printer's IP to a desired IP (similar to your local network) and restore then the IP of the PC to the one before.
Error type: connect
smb scanning? check to make sure host ip is conrrect as well as long in info and path to folder /email make sure smtp server address is correct along with login info and try port 587 if its set on 25 comcast tends to block 25 for smtp scanning
Jul 09, 2014 | Kyocera FS-1128MFP FS-1128MFP...
How do I install a new genuine kyocera developer unit (dv-172) in a Kyocera Y FS-1320D?
1-5-4 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the front cover.
3. Remove the developing unit (with toner container).
4. Check or replace the developing unit and
refit all the removed parts.
5. When the developing unit is replaced with a
new one, carry out the following procedure.
6. Perform toner install mode in the service
mode (see page 1-3-12).
May 26, 2014 | Kyocera Office Equipment & Supplies
How to check printer ip address
go to menu interface- option-netware-tcp/ip on - dhcp -ip address
Mar 08, 2012 | Kyocera Mita FS-1920 Laser Printer
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
Cannot access Advanced page via browser on KyoceraMita FS-1118MFP
THE page might have been removed from there permanently from the database of google.
try that again ,u can have.
Apr 01, 2010 | Kyocera Mita Kyocera-Mita - NETWORK BOARD...
Printer KYOCERA FS-1030D not geting connected to my local Netwok.
I cannot remember the name of the utility but I know on the new drivers for the newer machine it is built into it it discovers the machine baised on its mac address and you can change / set the ip from there.Try some of the utilities from the kyocera support sitehttp://www.kyocerasupport.co.uk/index/download_center.html
May 16, 2009 | Kyocera FS-1030DN Printers
Fixed IP adress problem
You can change it but it looks tricky, when scroll for the ip address hit go then use and up and down buttom to change it, you have to change the numbers too by using up and down buttoms after you finish, hit ok.
Nov 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera Mita Ecosys FS-1320D - 37 PPM Monochrome Duplex Laser Printer, FS1320D, 1102LZ2US0 Logo
789 people viewed this question
Top Kyocera Mita Computers & Internet Experts
David Payne
David Payne
Are you a Kyocera Mita Computer and Internet Expert? Answer questions, earn points and help others
