Question about GE Kitchen Ranges
WIRING CONNECTIONS DIFFERENT ON REPLACEMENT PART GE WB20KI0008,WHAT WIRES GO TO THE NEW CONNECTIONS?
  • GE Master
  • 2,992 Answers
Ask the store you purchaced from. There is usually instructions in the package.
Posted on Apr 11, 2015
I need a wire diagram to replace an oven thermostat in a hot point RB 525 R2W electric range,please help!! I already have the new part I just need a picture of the wiring connected
If you have an exact replacement for the thermostat. Draw a diagram of the wires and the location of the connections take a picture of the thermostat with your cell phone. Then compare the drawing to the picture to be sure you have all wires .once you have them all . Then if you have wires that are the same color but hooked up to different connections. Simply place a piece of tape on one of them and make note of it on your drawing . then Unhook the wires and reconnect them to new thermostat. MAKE SURE THE POWER IS off at circuit breaker.
Nov 20, 2014 | Kitchen Ranges
Installed timer and I'm getting breaker pop. I've tried several different ways to wire and it keeps poping the breaker. GE Replacement Timer 15600
1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
2) Double check your T103 terminals
T103 terminals should be A 1 2 3 4
If terminals 3 and 4 have wires, then GE is not correct replacement.
You can buy repair parts for Intermatic timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
GE has terminals 1-L X 2
4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
White wires on terminal A connect to terminal X
Black wire on terminal 1 connects to terminal 1
Black wire on terminal 2 connects to terminal 2
Sep 11, 2011 | GE Vacuums
I am replacting my T103 timer with a GE 15600. The posts on the T103 are marked 1 2 3 4. However on the 15600 they are marked L 1 X 2. How do these map to each other?
5) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Garden
I am replacting my T104 timer with a GE 15601. The posts on the T104 are marked 1 2 3 4. However on the 15601 they are marked L 1 X 2. How do these map to each other?
GE 15601 is a replacement module for Intermatic timers.
Intermatic timers can snap inside the old box without needing to replace the box, and GE has made a product that taps into that market.
But the GE manual is missing key facts like clock voltage and wiring.
The following information is correct ONLY if the GE timer is rated for 240Volts Why? The T-104 is a 240V timer. I have 10 different Intermatic timers on my office shelves right now, and wrote the T-104 page linked to above.
Below is picture of the back of GE timer taken from GE manual.
Please look at the image as a reverse image of your wiring poles.
T104 has poles A 1 2 3 4
Black wire on Intermatic Pole 1 is the Hot from Breaker
Black wire on Intermatic Pole 2 is the Black to Load
White wires on Intermatic Poles 3 and 4 are the White from breaker and White to Load. So on the GE timer, 2 white wires are on same pole.
On the GE timer, there is a brass connector between 2 of the Poles that connects those poles electrically, so no wire goes on one of the GE Poles
That's the wiring changeover.
Up-vote if the information helped you.
Oct 13, 2010 | Intermatic T104 24h 208-277v Mechanical...
GE THQB 1 pole 20 Oily liquid appears to be seeping from multiple breakers, different panels but not all breakers. Breakers installed 1992. Any thoughts?
There is no liquid in those breakers to seep out... my thought would be that some one used an anti oxidate compound on the wires when they installed them and that is running a bit as the breakers and wires heat and cool....
I would just check the wire connection for tightness and as long as the connections are tight I would not worry about it...
heatman101
Sep 03, 2010 | GE Circuit Breaker THQB BoltOn 1 Pole 15...
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box...
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Jul 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Power will not turn on
If you know the outlet is good then you need to unplug the AC slide it out of the cabinet and see if the on off switch is working or if there is a loose or burned connection in the wiring circuit. check all wiring going and coming to capacitors and check to see if the continuity between the post on the control switch. There are many different models and each one has different features. So each one may be wired a little different. While you are inside the cabinet mart the wires going to compressor and where they connect. Let me know when you get to that point and I will lead you through the way to test the compressor. I don't think the compressor is the problem, I just want you check all connections for burns or bad connections, Thanks, Sea Breeze
May 20, 2009 | GE AJCQ08ACB Air Conditioner
GE WASHER, REPLACED TIMER THEN BIG SMOKE
Be sure you are using the EXACT replacement part. The wiring may be different if it is a "close" match.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
Open Questions:
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
