Question about Ricoh Aficio 2018D All-In-One Laser Printer
How do you open the drum unit on an oficio 2018d
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 245 Answers
My dear you first side door open after you frand door open and remove drum unit
Posted on Sep 02, 2015
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: i have a Ricoh aficio
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Feb 03, 2011
Ricoh 2018D error code sc 500
Hello!
This error is related to a overload in the main motor.
It can be the drum unit stuck or a broken main motor.
I advise you to call a tech.
See you!
Aug 12, 2011 | Ricoh Office Equipment & Supplies
Hi i just want to asked y my output xerox paper is getting dark? What is the problem on my unit?
first of all do a service of your copier machine and clean all mirrors and lenses and the main glass.
then clean the chargers, transfer charger and primary charger. Primary charger is placed in Drum unit, clean the photo-conductive drum and its cleaning blade.
this may be useful for you
Mar 11, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Oficio 1515 tengo el eror SC 541
Fusing thermistor open error
Symptom: The fusing temperature remains lower
than the specified temperature by 20
degrees Celsius.
Possible Cause:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective power supply unit
• Loose connectors
Dec 04, 2010 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh aficio 2018d error sc302 can someone please advise what the problem is
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
Feb 17, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Kicoh, Aficio, 2018D is not displaying the ink on paper
if there is no message in the display than you may have your drum out a little , laser path blocked or no developer left in the copier. open the front door. the unit to the right is the drum push it towards the rear of the machine. try to make copies. if this does not fix it you need a tech to look at it so you are not just putting in arts spending money you do not need too.
Oct 05, 2009 | Ricoh Aficio 2018 Copier
Ricoh 2018D fuse unit
You probably won't find one new, the model is to old, used is your best bet.
Jun 01, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
