Question about Ruff Hewn 3-qt. Cast-Iron Casserole Pan
How do I get my money back from ruff hewn ? Daughter bought me 3 qt casserole used 1 time and it's peeling inside
  • 1,860 Answers
You'll have to contact Ruff Hewn and tell them about the product you have , you'll probably need your daughter's receipt for the casserole dish
Posted on Jun 19, 2015
Burnt on food on Corning Ware
Soak in hot water and baking soda overnight. Then scrub vigorously with a stainless steel scrubber or steel wool until clean.
Apr 19, 2014 | Corning Ware Wildflower 1 Qt Casserole...
I have the Mr Coffee Keurig model BVMC-KG5. It has only been used probably used less than 15 times. Now the water just drips out. Cleaned it per instructions which did not help. The machine was bought from...
It depends where the water just "drips out". It could be a leaking hose, or it could be the parts weren't put back together properly after you cleaned it. More information would be helpful.
Download Mr Coffee BVMC KG5 Manual
Feb 01, 2014 | Saeco Odea Go
Halogen tabletop oven
You can use any oven-safe dish that will fit inside the oven (preferably, with the low rack in place). I've seen 3 qt round casseroles that will fit when you aren't using the extender. (For example, this should fit: http://www.crateandbarrel.com/dining-and-entertaining/casseroles/lucerne-3-quart-casserole/s512853 ) Some casseroles are sold with non-oven safe lids. Make sure that you check the temperature range for the specific dish. Some are only rated to 400 degrees F.
Unfortunately, I do not know of any sources that sell the accessories separately.
I hope this helps.
Jun 03, 2013 | Fagor 12 Quart Halogen Tabletop Oven
Can I freeze apples whole or do they need cutting
Please allow me to give you some tips on how to freeze raw apples
Freezing apples will prolong the shelf life, and they will remain fresh for up to 12 months. However, after the apples thaw, they need to be used within a day or two because they will deteriorate quickly.
1. Select ripe sweet apples without large bruised areas. Apples that are firm will be easier to peel.
2. Rinse the apples under cold water. Dry them off with paper towels.
3. Dissolve 1/2 tsp. of ascorbic acid into 3 tbsp. of water. You will need 1/2 cup of sugar for each quart of peeled and sliced apples.
4. Peel the apples to remove the skins. Remove any brown spots from the apples with a sharp knife.
5. Remove the core from the apple. An apple corer will work best for this task; they are available at most grocery stores. Slice the apples into 1/4-inch to 1/2-inch slices. Remove the seeds, stems and hard areas of the apple.
6. Combine 1 qt. of apples with 1/2 cup of sugar and the ascorbic acid solution in a large plastic storage bag. Coat the apples evenly with the sugar and solution.
7. Pack the apple slices into freezer containers. You can also freeze the slices on a cookie sheet and then pack them into containers to prevent them from sticking together in clumps.
Thanks for consulting FixYa
Good day! : )
Sep 07, 2011 | Refrigerators
What is the oil capacity of an2002 xterra - 4 cyl?
Oil Capacity (Approximate)
DRAIN AND REFILL
With Oil Filter 3.5 l (3 3/4 US.qt, 3 3/8 Imp.qt)
Without Oil Filter 3.3 l (3 1/2 US.qt, 2 7/8 Imp.qt)
DRY ENGINE (engine overhaul) 4.1 l (4 3/8 US.qt, 3 5/8 Imp.qt)
Jan 01, 2011 | 2002 Nissan Xterra
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Changing date & time on the QT-6000
1. Press [Mode]
2. Press [PGM1]
3. Input current time (in 24hours format, eg 9:30pm = 2130)
4. Press [X/Date time]
Aug 22, 2009 | Casio QT 6000 Point of Sale Terminal
Rock band ps2 disc
THis is my complaint letter I have sent out tonight:
My daughter and I went to Walmart in New Ulm, Minnesota tonight. She took her savings of $130.00 that she earned rock picking this summer to buy the game "Rockbandfor playstation2" for her playstation2. (FYI her playstaion2 is slim model numberSCPH-70012)
We got home and she happily opened the box and quickly put everything together and hooked it up. The disk was "unreadable" it stated "there is no data"
There was a pink slip inside the game stating to go to http://supportea.com/rockband if there was a problem with the game. I went to the site and called the phone number stated on the site. I was told that the Rockband game did not work on certain models of the playstation 2and there were lawsuits against sony because of this.I was told there was nothing they could do. I was told to call Sony at 1-800-345-7669. I called Sony and they told me they knew nothing about the so called lawsuits against them that "ROckband" told me. Sony said I could give them my credit card number and for $45 I could mail it to them and they would look at my playstation 2 console. Note: ALL OTHER PLAYSTATION GAMES WORK ON MY PLAYSTATION! Rockband is the only one that does not. Sony told me I needed to call EA (ROckband) . I called ROckband and talked to supervisor Steve. He said I could return the game (which is a HUGE box with drums etc in it ) at my cost and if found defective they would send me a factory sealed new game which I could return to Walmart and get my money back. I do not have the money to pay for shipping on this......I asked for a prepaid shipping label and they said no they could not do that.
I then called the New Ulm Walmart and talked to Asst manager Mike. He gave me the same answer as SOny and Rockband ultimatley gave me.....THere was nothing they could do. THe box was opened and federal law says they cannot take electronics back. He knew nothing about this game being faulty with certain models of Playstation2 systems.
I told all 3 of these companys that there should be a recall.....that they are aware this Rockband Playstation2 game does not work with certain Playstation 2 consoles. There should be some sort of label on the box stating this!!!!
My 14 year old daughter worked hard for that money she spent on this game! All I want is the money back!! I told Walmart they should not have these games on their shelves!!! I had purchased the game an hour before I called Walmart to ask if I could please return it and they said it would be against the law for them to take it back.
Do I need to buy a new playstation2 (which I cant afford!) and what if that playstation is one of the faulty models....then I am stuck with another useless playstation.......
Its just so ridiculous that my daughter bought this game and she can't even use it and can;t take it back to get her money back. We bought this game a couple hours ago and my daughter has been so upset about all of this she has been in tears. She has saved that money for a long time and finally decided to make this big purchase........We made a special trip to the New Ulm Walmart from Springfield just to buy this game..............
You would think big cooperations such as Sony, EA or Walmart would be willing to at least send a prepaid shipping label to help us out in this situation.
They are ripping consumers off!!!! Its a disgrace!
Jul 20, 2008 | Sony PlayStation 2 (PS2) Console
About motorola t5720
Hello, Thanks for requst me, As far as I understood, you have same settings in both radios, you mentined QT this is the 3° requirment to recive a signal, 1° channel, 2° subchannel (ctcss, pl, etc) and the 3° QT.
if you are using QT you must to send a Call from the other radio, I recomed to set the QT to Off in both radios and tray if you can communicate in both directions.
if does not receive, there is the possibility that one of your radios the Sub channel decoder is not working.
If you could test your radios with a Third radio to know wich radio is not working right.
Good luck
Apr 28, 2008 | Motorola Talkabout T5720 (7 Channels)...
Ruff Hewn 3-qt. Cast-Iron Casserole Pan Logo
77 people viewed this question
Top Ruff Hewn Home Experts
Donni Steen
Tom Chichester
Are you a Ruff Hewn Home Expert? Answer questions, earn points and help others
