Question about Intex New - Twin Pillow Rest Raised Airbed
It overinflated and looks like a beach ball - Intex New - Twin Pillow Rest Raised Airbed
How many ball bearings are there supposed to be on each side of the front axle of the Schwinn Point Beach model S4852WM bike?
There will always be a small gap in the bearing ring, and not all hubs take the same amount. However, if the balls are 3/16" there are almost always 10 on each side. If they are 1/4 inch (less common) then 9 is the correct amount. DO NOT replace only some of them - replace only in a full set of 20 or 18.
Sep 10, 2016 | Schwinn Cycling
My daughter says there is a toy that is a ball that bounces on the water. Is she right?
Yes she is - the Waboba surf is a great toy. It's brilliant fun in the pool and in the sea with all the family as it's a ball that actually bounces on the water.
Check out this info about it;
http://www.amazon.com/Waboba-Surf-The-Ball-Bounces-Water/dp/B004RGU0SK/ref=pd_sim_sg_6
Feb 28, 2013 | Toys
We have just discovered beach paddle ball and now want to buy our own set. Where should I shop?
Beach paddle ball is very popular as a beach game these days and you can pick up sets really cheaply - see this link for an example;
http://www.partycity.com/product/beach+paddle+ball+set+4pc.do
but if your kids are a bit older, and you play a lot, you should consider investing in a set that has been made well and will endure many hours of hard play.
Feb 28, 2013 | Toys
Is there such a thing as beach toys for adults?
Sure - even adults are entitled to have some fun on the beach. Take a look at boogie boards, inflatables, paddle boards and there are also loads of ball games, with and without rackets on sale.
Feb 28, 2013 | Toys
Spinning beach ball
Try looking for help on how to create an 'animated gif'
Jan 15, 2013 | Adobe Photoshop CS6 Extended - Mac
Why does my SSD cause the beach ball of death on OSX?
Try a NRAM/PRAM/SMC reset.
The best thing is to get a copy of OSX 10.8 3, load it to a flash drive or burn to disk, then secure erase the SSD with the erase tool from Crucial, do a fresh install of OSX.
Then do a reset of these again, its the best way to get the system working with no problems.
That is a good SSD.
Just google NRAM/PRAM/SMC RESET and read how for your Macbook pro.
Then get a small external drive for backups, so you can secure erase the drive when needed.
Remember Apple turns off TRIM when its not one of their SSD's, so you need to give the drive time to use garbage collection.
You can Google TRIM enabler, but if you have any problems after installing it and turning it on, just turn it off.
I have no problems with it.
A new update for 10.8.3 is coming soon to public, beta 12D76 is working great.
Dec 06, 2012 | Crucial Technology CT512M4SSD1CCA 512gb m4...
2000chevy tahotires chirp upon take off
Not a bad sign for your drivetrain...sounds solid without any play...Be sure you are inflating all tires to the Tahoe's specs...these tire sizes and air pressures are usually found on the frame around your drivers door...Your owners manual may help too. Many tire stores list the recommended air pressures in their computer system info for most cars and trucks. However, sometimes there system is incorrect. Many owners will inadvertantly overinflate there tires due to the spongy sidewall of the radial tire. Overinflation will also lead to tire noises at take off, and cornering, and stopping. When you decide to look at tire replacements...remember that all tires are NOT the same:) Reading the reviews on-line by other consumers is usually helpful. Hope this helps.
Apr 03, 2012 | 2000 Chevrolet Tahoe
Had brakes done 4 wks ago; had them rechecked 7 days ago due to excessive squealing. I was told that I needed new ball joints, upper & lower. $800 later, my brakes still squealed and my left front...
The squeal is not caused by the ball joints. A lot of times it is caused by the kind of brake pads put in there or the brake disk needs to be turned. Honestly you should take it to an ase certified shop who knows what they are doing.
May 24, 2011 | 1999 Mercury Grand Marquis
How to inflate the shake & monkey rattle ball?
Look for a plug on the plastic ball, it may be under the monkey fabric cover. Pull plug and blow air in just like inflating a small beach ball. Re-insert plug to seal.
Nov 06, 2010 | Toys
Intex New - Twin Pillow Rest Raised Airbed Logo
566 people viewed this question
Top Intex Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you an Intex Rock and Ice Climbing Expert? Answer questions, earn points and help others
