Question about Casio FX-9750GII Graphing Calculator
How do i turn off the scientific notation - Casio FX-9750GII Graphing Calculator
  • Casio Master
  • 8,073 Answers
In Run/mat press SHIFT MODE (Setup). Scroll till you reach display. Select any thing except scientific. In general, choose Norm1 or Norm2
how do i turn off the scientific notation - 25617605-oje5zyhnqai35ijetm02ysxa-5-0.jpg
Posted on Jul 29, 2015
  • 8073 Answers
SOURCE: how to turn off scientific notation?
Press [SHIFT][MODE][6:Fix] (number between 0 an 9) to select the number of decimal digits you want. Then press [=].
Hope it helps.
Posted on Oct 09, 2009
  • 8073 Answers
SOURCE: HOW DO I CHANGE MY MODE TO REGULAR MATH EQUATIONS
Press [SHIFT][MODE][6:Fix] and press a numbetr between (0--9). The number you select will be the number of decimal places your results have.
However if a result is smaller than 0.001 it will be in scientific notation.
Hope it helps.
Posted on Oct 10, 2009
  • 8073 Answers
SOURCE: scientific notation
You have a key marked [x10^X] located on the bottom row of keys.
Example: To enter 6.02x10^(23)
6.02[x10^X] 23 [=]
If you have a negative exponent, use the change sign key [(-)]
Posted on May 24, 2010
  • 146 Answers
SOURCE: After working a simple problem adding numbers in
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Posted on Jun 10, 2010
Testimonial: "Very quick and helpful response. Thanks much"
  • 8073 Answers
SOURCE: Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Posted on Jul 18, 2010
How can I change the threshold for scientific notion rounding in normal display mode on my Casio fx-9750GII.
[PDF]fx-9860G Series_fx-9750GII_fx-7400GII_Software Ver. 2.0_Eng - CASIO
support.casio.com/pdf/004/fx-9860GII_Soft_E.pdfThe contents of this user's guide are subject to change without notice. ... For full details on availability in your area, contact your nearest CASIO ...... The calculator normally displays values up to 10 digits long. Values that exceed this limit are .... The fx-7400GII and fx-9750G II are not equipped with a Math input/output mode.
SOLVED: Scientific notation on the casio fx-9750GII - Fixya
www.fixya.com/support/t20210775-scientific_notation_casio_fx_9750gii
Sep 20, 2013 - Press [SHIFT][Menu] to open (Setup). Scroll Up to reach the line Display, press [F2] (Sci), type in the number of decimal digits, press EXE. See the screen captures below. Scientific notation on the casio fx-9750GII
Mar. 13, 2017
SOLVED: How do i turn off the scientific notation
Mar. 30, 2015
Using Scientific notation on the casio fx-9750GII
Oct. 5, 2013
Casio FX-9860G Graphic Calculator Scientific ...
Oct. 18, 2011
More results from www.fixya.com
How can I use scientific notation on casio calculator? ' Socratic
https://socratic.org > ... > Correct Use of a Scientific Notation on a Scientific Calculator 7 days ago - Most scientific calculators have a button EXP ...type in a number, press EXP , AND then you asked to input the exponent as a power of 10 .
videos
casio fx 9750gii scientific notation Google Search
Jun 18, 2018 | Casio Computers & Internet
What does the E code mean
Does the E code look like 10.8372487489E12?
If so, the calculator is either set to scientific notation mode OR the result was an answer that was too big to display on the calculator, so it converted it to scientific notation. To convert from scientific notation back to regular notation, move the decimal to the right by the number of times after the E. In this case, the number after the E is 12, so we have to move the decimal to the right 12 times. In this case, I get the final answer as 10 837 248 748 900.
Good luck.
Any questions, let me know.
Paul
Jan 11, 2016 | Office Equipment & Supplies
Scientific notation
All calculator use scientific notation if the result is too small or too large. Some, like the Casio FX9750G II, offer you two Normal displays, Norm1 and Norm2 that have different limits when numbers are converted to scientific notations.
Here is how to set one or the other.
In Run>Mat press SHIFT MODE (Setup). Scroll down or up to reach the display line. Press F3 to select Norm1 or Norm2.
Oct 22, 2013 | Casio FX9750GII Graphic Calculator
Turn Scientific notation off
Press SHIFT then MODE then press either 6 to specify a fixed decimal notation or 8 to specify floating decimal notation.
Sep 16, 2011 | Casio FX-115ES Scientific Calculator
I want to remove the word fix from the top of the calculator
You've got the display set to fixed decimal notation. To change it, press SHIFT MODE 7 to switch to a scientific notation or SHIFT MODE 8 and then 1 or 2 to switch to one of the norm display modes.
norm1 switches to scientific notation if the magnitude of the number is less than 0.01 .
norm2 switches to scientific notation if the magnitude of the number is less than 0.000000001 .
Jun 07, 2011 | Casio FX991ES Scientific Calculator
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
Scientific notation when not wanted.
Unfortunately, you don't. For numbers whose magnitudes differ too greatly from 1, the calculator automatically switches to scientific (or engineering) notation. You can press MODE and change the display settings, but there is no setting that will force the calculator to show this number without an exponent.
Feb 25, 2010 | Texas Instruments TI-83 Plus Calculator
HP 12C went into scientific notation and will not come out of it
To exit the scientific display format press the [f] key followed by the number of decimal digits you want.
Hope it helps.
Oct 31, 2009 | HP 12c Calculator
Casio FX-9750GII Graphing Calculator Logo
1,259 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
