Question about Garden
Riding mower revved up and now wont start
I was mowing and all of a sudden the engine revved way up. I killed it and tried to restart it several times but the engine was revved way up. after a few tries, it wont start or do anything now. what would I need to check for?
  • Garden Master
  • 2,321 Answers
I am wondering if you have a broken spring on the carburetor. There are springs that hook the linkage up to the lever you use to speed the engine up, Also on the carburetor its self. If a spring is broken the engine may rev out of control and yes it has to be repaired to start don't try to run before repairing or you will blow it up.
Posted on Mar 30, 2015
  • 1 more comment
  • bjnbsullivan Mar 30, 2015
    Is there somewhere online that will give me a diagram so i can tell what spring is missing?
  • Eugene Rounds Mar 31, 2015
    Yes there are diagrams for various engine online but the engine numbers are required to link some for you.
    The could be worse than a broken spring as governor itself may have failed.
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Tip
Safety For Riding Mowers
<span> <ul> <li>Do not give children rides on a riding mower, even with the mower blades not turning.</li> <li>Children may fall off and be badly injured or interfere with safe machine operation.</li> <li>Children who have been given rides in the past may suddenly appear in the mowing area for another ride and be run over or backed over by the machine.</li> <li>Do not mow with a riding mower in reverse unless absolutely necessary.</li> <li>You can be seriously injured or even killed if you use a riding mower on too steep an incline.</li> <li>Using a riding mower on a slope that is too steep, or where you don't have adequate traction can cause you to lose control or roll over.</li> <li>Always consult your operator's manual for safety messages concerning operation on a slope.</li></ul></span>
on Apr 02, 2011 | Garden
Kohler engine troubleshooting
I would be looking into the governor system... starting with the spring and then internal... but I would also looks at the connection at the carb... any play, damage ???
Sep 01, 2014 | Garden
John deere x485
Bad fuel or clog fuel filter or fuel lines are bad
Aug 12, 2014 | Garden
Sears lawnmower kills after mowing for 10 minutes doesn't restart till rested a long time. Repair man says nothing wrong with it.
That is the symptom of a failing ignition module. With the airbox cover and air filter removed run the unit till it fails. Immediately squirt a shot of carb cleaner into the carb and try to restart. If it restarts see if you can keep it running on the carb cleaner for a few seconds. If it wont restart or stay running then its likely an ignition module. If it does restart and keeps running on hte prime then you have a fuel issue.
Other things to check: spark plugs can fail when they get hot, checkt o make sure the engine stop cable is pulling the bail off ground sufficiently. If the cable has stretched it may not pull the bail completely off ground causing intermitent spark.
Nov 17, 2012 | Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
I ran over a steel stake that locked up my blades and killed the engine. Freed jam, engine will still not start. Is there a safety reset?
hello,check the key way on the flywheel,when engine is stoped suddenely this will happen,shears the keyway and throws out of time,want start,hope this helps,
Feb 18, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
