DOS IT HAVE BATTERY BACKUP - Computers & Internet
    Master:
  • 496 Answers
No. You will need to replace your battery if there is a warning... or your battery doesn't hold charge.
Posted on Mar 30, 2015
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
Remove bios password
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords...
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Aug 24, 2012 | Battery Biz WIPRO AcerNote 350cx AC...
Onde esta a bateria do laptop bios
Contrasenas de BIOS se puede restablecer o eliminar de dos maneras:
1. el uso de software 2. el uso de hardware.
La primera vez que se intente restablecer o eliminar el uso de software, aqui hay dos aplicaciones de software para restablecer o recuperar contrasenas de BIOS.
! BIOS - es un conjunto de herramientas que ofrece PC BIOS contrasena eliminacion / descifrar y modificacion de configuracion del BIOS / backup / restore.
Se puede descargar aqui:
CmosPwd - CMOS herramientas de recuperacion de contrasenas
Usted tendra que crear un arranque de DOS, Linux o NT o cd para ejecutarlos.
Buena suerte!
Aug 17, 2012 | HP Compaq nx6310 Notebook
How to reset the password in BIOS on Gateway laptop?
see if u can do a cmos reset - try a dos comso wipe utility,
or see if you can find a cmos reset jumper, move it for 10 secs and put it back where it was
or open the laptop and remove the backup battery (along with the system battery) for a while then replace it
Any further questions feel free to ask.
Nov 19, 2010 | Computers & Internet
My computer wont show the drive and i cant retreve any of my backups. It has worked fine untill now .
does it show up in the bios on boot?
if not your almost hosed... you need a new controller board for the drive or install the internal disks into a forensics drive kit. (i would take the drive to a recovery specialist. its cheaper than ebaying the parts needed). or just take the cover off and show the kids, display on the wall ect...
if it shows up in the Bios then try a bootable cd, (windows install disk will allow you to drop to DOS).
from dos explore the drives
cd c:
should bring you to c:
mkdir backup
will make a directory called backup
cd d:
should bring you to d:
copy *.* c:/backup
will copy all files in the current directory to the C: drive to the backup folder. path through and get the files you want.
Jun 10, 2010 | Western Digital 320GB MyBook External USB...
Blue screen "unmountable_boot_volume" on toshiba portege 3505...only get error when battery is in laptop...can't turn on laptop at all when battery is not in laptop...help!
try to boot to windows xp or dos command, for winXP go to recovery console-select your windows-type the admin password then if C:\WINDOWS come up type chkdsk /r if that doesnt help, repair your operating system or backup your files and reinstall your operating system.
Feb 23, 2010 | Toshiba Portege 3505 Tablet PC
Cursor frozen and cannot cut the computer off or move the cursor
Ok try to boot in native DOS if the unit still froze. If it froze then check your memory card, reseat or clean it with soft eraser only its edge connector. Do this when battery is disconnected and no any other power source is connected to the unit.
Then if it run native DOS. If you can backup your important files, installation code. This will end restoring your unit to restore factory, do you have your restore disc?
Or you can try first to run in safe mode/repair options. Check if it can do some system restore.
May 15, 2009 | Compaq Presario 1200XL104 Notebook
How to install windows 98 in ms-dos based
go to the windows(as your windows backup stored) directory and
just type setup and press Enter
write me for more help,, tell me where is your windows 98 backup is --in CD or computer HDD.
Nov 29, 2008 | Microsoft Windows 98 for PC
I need to know how to reformat my acer extensa 4220. I have no boot disk and I have a virus that is not allowing me to see my system information or MYcomputer and so forth
first create a boot disk.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
You Will Have your own Boot Disk.
Backup Your Data.
Boot With the help of BootDisk.
Load a new XP.
Virus Scan All the Drives and Data.
Sambeet
Sep 19, 2008 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
