Question about Ovens
Fan has stopped working in lower oven. Now only works as a conventional oven.
Before it stopped working noticed sparks from fan.
  • 473 Answers
Sounds like you have a either a bad fan motor or the wiring broke or came loose from the fan motor. Sparks indicate a wiring problem at that area or motor burn out.
Posted on Mar 30, 2015
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
ZUQ 875X double oven. When fan oven is selected, fan operates but oven does not heat up. Ok on conventional oven selection.
If fan is working ok, then I would suyggest that you check the fan oiven element, as it it sounds as though this is faulty.
Please rate my solution.
Thanks.
Nov 04, 2009 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
FAN COOKING MODE ON COMPETANCE B4101-4 NOT WORKING FAN WORKING BUT NO HEAT CONVENTIONAL MODE OK
If fan is working o/k, then you need to fit a new oven element.
Thanks.
Sep 26, 2009 | AEG Ovens
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
LOWER OVEN DOESN'T HEAT WHEN FAN IS SELECTED
Hi Ginozzzz,
Sounds like it could be the Fan Oven Switch - especially when it works on the conventional oven. Does it have a separate element for the Fan Oven? If it is not the switch it could be the Fan Oven Element. Unfortunately I am not familiar with the oven so thats about the best I can do for you.
Regards
Bryan
May 26, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
