Hydroshakti 65 semiautomatic washing machine rotating in only one direction.
  • Washing Mach... Master
  • 5,323 Answers
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS
Posted on Apr 16, 2015
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: onida hydroshakti 60E washing machine
Yes - you can do both at once.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
The drum in my washer will not rotate. Are they belt or direct drive?
Every washer I have dealt with have all been direct driven through a transmission. There are several reasons that a washer drum will not rotate. The simplest reason is that the door interlock is not functioning properly.
Aug 05, 2016 | Washing Machines
Drum or basket rotates 3/4 turn one direction the pauses 10 seconds then rotates 3/4 turn the other direction during wash cycle. Does the same during spin cycle.
This is normal operation for the machine It is doing this to get detergent and water to all of the loaded cloths and also to balance the load for when it is washing and spinning
Nov 05, 2015 | Maytag MAH21PD Front Load Washer
How does clutch assembly work on lg wft 1022 tp
ITS BELT DRIVER,WITH WASH MOTOR,,, ITS CONTROLLING BY DRAIN MOTOR,,BY THE DRAIN MOTOR CLUTCH FULLING & RELEASING,,,AT THAT TIME ONLY WASHING,,SPINNING,RINCEI TIME DRUM ROTATING ,,,
Jan 19, 2014 | LG WFT1071TP Top Load Washer
My Onida Semi Automatic Washing machine Hydrofall 70S model Spinner is not working
onida semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Apr 28, 2013 | Washing Machines
Machine rocks, all four sides, removed and oiled clutch bearings, tightened the belt, still rocks and errors out no matter the size load, machine is balanced. ?
I feel you still have a clutch problem... Did you try this test before you cleaned up and re-lubed the One-Way Roller clutches in the Clutch pulley?
From my Clutch Fix post;
Let's demystify dC and uC error codes plaguing the FAV6800A and the LCD Flavor FAV9800A
One last step before you clean up those pesky Clutch Pulley One-Way Roller Clutches/bearing.
Holding what I call the Spinner Shaft coupler first picture. Insert that coupler into the Clutch One-Way Roller bearing plate.
Now while holding the Spinner Shaft Coupler with one hand as I show in the second pic with your other hand rotate the white bearing plate in the CW direction around the Spinner Shaft Coupler.
The One-Way Roller Clutch bearing plate should rotate freely in the CW direction this is the wash/agitate direction.
Now rotate the One-Way Roller Clutch bearing plate in the CCW direction it should lock up solid.
Most times the One-Way Roller clutches will slip did it slip for you? This will cause the agitator shaft to move slightly causing slight tumbler rotation while the wash basket begins to spin up unbalancing the wash load causing big time wash tub swings and those pesky unbalance error codes.
The Control Board sees the TDS analog voltage swings out of design limit and shuts down the spin cycle. If the TDS was not working as designed the machine would walk across the room and unplug itself or self-destruct.
The Control Board programming will try several attempts to redistribute the wash load and when the magic number of wash load redistribution attempts has been reached the Control Board signals a dC or uC error code to the display. I believe the FAV9800A signals a text error to the display i.e. "unbalance condition?" or something like that.
Anyway I thought you might want a little more insight into just what is going on here. A very poor Clutch design by Maytag. Mine failed at the 3.5yr mark of service and I was not about to trash a $1K machine. Sorry to say I feel number of them do make it to the curb on bulk trash pickup day.
I call this the Spinner Shaft Coupler. Not sure what Maytag calls it.
This is the One-Way Roller Clutches/bearing.
While holding the Spinner Shaft Coupler with one hand rotate the white One-Way Roller Clutches/bearing plate in the CW Wash/Agitate direction with your other hand. It should rotate freely in the CW direction around Spinner Shaft Coupler.
Now rotate the white One-Way Roller Clutches/bearing plate in the CCW direction the Spin Cycle direction. It should lock up and not rotate CCW around the Spinner Shaft Coupler. If it does the tumblers will rotate slightly and cause the wash basket load to go off balance as the wash basket spins up.
If the TDS is working as designed the machine will fail in Spin Cycle with dC or uC error codes. If the One-Way Roller Clutches/bearing can be cleaned up and re-lubed you could be back in service with no cost.
If so what were the results?.................Rich
Oct 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I need a user manual of whirlpool semi-automatic washing machine
whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Sep 22, 2010 | Whirlpool Washing Machines
Maytag FAV6800AW have replaced clutch and cleaned under tumblers. Machine will not balance. When rotating tumblers entrie drum rotates (during cycle). I removed drum and no leakage out bottom. Does this...
Let?s see if I understand. Are you in a wash/agitate cycle when this happens? If so is the wash basket rotating Clock Wise with the tumblers rotating (washer top raised for observation)? With A Spin Only cycle selected and some clothes in the wash basket. Raise the washer top from the base and observe the wash basket rotation. The wash basket will rotate CCW the spin direction. Do the tumblers rotate while the wash basket is rotating CCW? If so the load will go off balance. What series is your machine it will be the first two digits of your Serial Number i.e. 10 through 17. Was the original clutch replaced because of severe rust of the One-Way Roller clutches/bearing in the clutch Pulley assembly? Do you have the original clutch pulley assembly? Did your machine use the upper the One-Way Roller clutches/bearing ring? Your series number will help me but if you can confirm. I?ll try to help?.Rich
Jan 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Onida hydroshakti 60E washing machine
Jan 08, 2009 | Washing Machines
Hoover Washer only agitates in one direction
Check the paw. It is a plastic somewhat u shaped piece that sits on the bottom of the machine and is connected by a plastic lever and a solenoid. It usually breaks on the end and as such won't lock the gearbox in. If you keep running it like that there is every chance you will probably burn the motor out.
Oct 08, 2008 | Washing Machines
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
