Question about DCS Ovens
My DCS oven display went out and I have replaced the 211696 display board...worked for a minute then started flashing fc and beeping...any ideas?
localwonder
  • 6784 Answers
SOURCE: Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Posted on Jul 27, 2009
milten1
  • 1304 Answers
SOURCE: need a service manual for wo-127ss DCS single wall
you can call dcs, they will be happy to send you a manual,
but mostly, this should be pretty simple, three small black phillips heads hold tthe console down, the are above the door when closed
from there the panel should tilt forward and off
becareful they dont leave much room. or very long wires
Posted on Oct 13, 2009
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Posted on Jan 21, 2010
  • 19 Answers
SOURCE: beeping and FC code
check to see if you have a fuse blown to your stove and replace it
Posted on Oct 05, 2012
  • 36 Answers
SOURCE: Where can I find part no 211696 for dcs oven?
what is this part called and where did you get the part number,then i will help.
Posted on Oct 12, 2012
Display went out on my whirlpool RBD305 oven and then it stopped working
You will need to replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Whirlpool RBD305PD Electric Double Oven
Oct 12, 2012 | DCS (WOTD-227) Double Oven
Beeping and FC code
Oct 03, 2012 | Jenn-Air Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Dcs oven display dim - need part #
Jul 19, 2009 | DCS (WOTD-227) Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Ovens Logo
Top DCS Ovens Experts
ashburton
Joyce Nokleby
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
