Question about Philips Norelco 1250x Sensotouch 3d Electric Shaver
Want to clean blades. How to take apart - Philips Norelco 1250x Sensotouch 3d Electric Shaver
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
Oct 11, 2009 | Vidal Sassoon VSCL828 Hair Trimmer
I do not know how to clean and take it apart
I did some research here on Fixya and this is what another expert had to say.........pull the metal bar forward and down to open up into the blade compartment. your juicer should have come with a handle type key wrench thing that you stick on top of the blades into holes to unscrew blade holder, while unscrewing that hold the blade still.
Hope this helps you......best wishes.
Oct 05, 2009 | Jack Lalanne Power Juicer 250 Watts
HOW DO I GET MY JUICER APART TO CLEAN IT
I looked all over for the disassembly instructions for the JM300 to no avail...so I got a flathead screwdriver and decided I'd either get the darned blade out or break it for good. It took some prying but the blade popped out and it was the RIGHT way to handle it after all. Now everything is clean and ready to use again.
Sep 14, 2009 | Juicers
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
I need to know how to take this puppy apart for cleaning...
If you don't have the orange blade tool, just find a big wire around 1/8 diameter. Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves.Turn the blade.
Apr 11, 2009 | Juicers
How to clean blade and screen
First thing you need to do is take it apart, which can be done pretty simply until you get to the actual blade and strainer. You will need to use the crescent tool, the one with two pins. Insert it in the blade, and turn it counterclockwise while holding the filter so it doesnt turn. All the parts should come apart easily.
i find the best way to clean these parts is using a small brush, not a sponge or rag.
Mar 02, 2009 | Jack Lalanne Power Juicer 250 Watts
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Philips Norelco 1250x Sensotouch 3d Electric Shaver Logo
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
