Question about Fuji FinePix Cameras
Camera won't switch on using batteries or external supply!
Camera Model 602Zoom won't switch on
  • 28 Answers
Dear!
Fuji product! The is so old, it is better to bring your nearest local repair shop check! But at least you can do yourself easy so you can save time and money. Check really well your camera battery contact both battery compartment inside using flash light and magnifying glass and battery cover contact. You can use eraser and rubbing alcohol to clean.
Hope you lcuk! A Professional Camera Clinic Guy!
Posted on Mar 31, 2015
Iloilo city
try a different battery or use an external charger.... the battery could be faulty, or the camera charge function could be faulty.... a different battery will help you decide where the problem is.
Apr 05, 2014 | Nikon Cameras
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
Camera does not respond
I see you can't even look on the screen, because you have to start the camera first, before you can switch between taking pictures and viewing. You you not even can see an error displayed on the screen.
Most obvious is the battery, or its connections. The manual says:
"The camera does not work even when batteries are installed."
Insert recharged batteries in the correct direction. "Inserting the battery and the SD/SDHC/SDXC memory card (sold separately)" (p. 13), "Charging the battery and setting up using the supplied CD" (p. 14), "Charging the battery with the supplied USB-AC adapter" (p. 17)
Battery performance may have been reduced temporarily due to low temperature. Take the batteries out of the camera, and warm them by putting them in your pocket for a while.
Then to make sure it is not the battery they advice to connect an external USB-AC adapter.:
An F-3AC USB-AC adapter (available separately) is recommended if the camera will be used for extended periods.
Note that the power cable supplied with the USB-AC adapter is for use exclusively with the USB-AC adapter. Do not use with other devices.
With the adapter, the voltage (and current it can deliver) could be enough to switch on the camera.
If it works, you should take aout the battery and check if the connection point of the battery and in the camera are clean and shiny. If not, please clean them with a dry cloth. Never use a sharp tool to clean electronic contacts. The manual says the battery will live up to 300 charge / discharge cycles. If the camera won't work with the battery and it works with the USB AC adapter, replace the battery.
Nov 16, 2013 | Olympus XZ-1 Digital Camera
Any idea where I get a replacement charger for a Metz60CT4
EBay, if that's what you want. The metz "chargers" are just 7 volt ac transformers - they supply 7 volts to the battery pack which has the actual charging circuit in it. I haven't pulled one apart yet, but I'm guessing they're very rudimentary chargers. Depending on what you're using for a battery you might want to use a modern external smart charger. I use $20 AGM batteries from batteries plus (instead of the $80 metz batteries) and use an external charger from WallMart on them. It's quick, lets me see the current charge state, won't overcharge the battery, and works on my car and boat batteries too.
Jan 24, 2012 | Metz Mecablitz 60CT4 TTL Flash
My Lumix DMC-LX5 camera won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
Nothing works
i cant help you if you note decrib exactly the problem...please say me what you have does with the camera..be for ffaulty or you have see that the camera dont works...have you proove if the camera works with a external suplly... look your camera has a 5 volt jack find a external supplies for 5volt plus internal minus external in the plug in jack proove if the camera works...if the camera works with external supply this is a typical fuji defect ..the internal board have burn the alimt....fuse
and the camera dont work with akkus or batteries paolo italy
Nov 18, 2010 | Fuji FinePix S1 Pro Digital Camera
Does it use battery only or charger
It depends on the Model of the camera. Few camera's do have that function and few don't.
However, most models do not have this feature as this would require a built in charge circuit, which would complicate the design and definitely increase the size of the camera. Even large cameras don't (usually) have built in charging circuits.
The thing to remember is that in order to charge the battery you must have the same voltage as the original charger. USB ports only supply 5volts... typically at 500mah or less. If your camera does not allow for the battery to be charged in the camera then it won't matter because you will need an external charger.
Be careful about he type of external charger you buy because lithium batteries are dangerous if charged incorrectly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 23, 2009 | Samsung Digimax 4010 Digital Camera
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Cameras Logo
110 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
