Question about Electrical Supplies
I have a colemen Powermate plus 5500 and I have gas in my oil why
I have Gas in the oil resivoir
  • George Ippolito
    George Ippolito Mar 30, 2015
    It has only been started every three weeks for 5 minuts to make sure it runs.
    Top Expert:
  • 51,591 Answers
Most likely the float in the car stuck and let the tank drain into the engine block . happens all the time with tanks being above the motor
Posted on Mar 30, 2015
    Top Expert:
  • 10,875 Answers
Rings are shot
How to drain gas from colemen 6250 gen. is there a drain or do i have to remove gas tank.
Just pull the gas line off of the carb. If the end of the hose is difficult to access, you can cut the hose, then put it back together with a brass hose barb. To be sure of the size, you can cut of a very short piece of the hose. I've been looking for a drain valve that could be installed instead of a hose barb myself. I don't know why these medium sized generators don't come with them.
Nov 05, 2010 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate PRO-GEN 5000 (6250). It has been sitting for a year and the gas value was not shut off (oversite). When checking the oil, it smells like there is gas in the oil-is this possible?
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Aug 03, 2010 | Coleman Powermate Premium Plus 6250W...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6875 engine runs fine and it all works till it gets hot then the engine still runs but not charging.
The unit should have a pop out fuse or set of fuses.
If you are drawing too much currant from the unit, it will shut down. If you plug in a simple 100Watt light and test the unit and see if it stops generating currant.
Max is only 5500.
You may also have shutoff thermo sensiors, if the caseing of the generator runs too hot or low on oil, it will shut unit down.
Keep in mind, if you have a shut off valve, turn the shut off valve, closing the fuel supply while running.
This will remove all gas from the bowl and not spoil after setting for long periods of time.
Same with oil, it will do damage to the engine if it just sets for long periods.
Sep 23, 2009 | Coleman Powermate Premium Plus 6250W...
Have a colemene powermate that will not stay started
bad fuel? or varnished inside of carburetor needs to be removed all ports and jets thoroughly cleaned out should solve your problem
Jan 08, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Oil to gas ratio for Coleman Powermate 5000?
my powermate is straight gas.......be careful. go to colman web site and download service manual. mike
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Sep 29, 2008 | Air Tools & Compressors
Electrical Supplies Logo
42 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
