Question about Ariston Technologies Dishwashers
What is wrong then the 4th and 5th lights from the left are flashing together
Model is Elixia LI 68
  •  johnny rebel
    johnny rebel Mar 30, 2015
    Hi Simon Forster, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
When purchased, upon starting the car, the radio (manufacture model) volume knob would actually be turning down when you were turning the radio knob up, and it did the opposite if turning the knob up, the...
sounds like a serious electrical issue there hard to track down could be the computer staarting to go in car the radio could of been hooked up wrong causeing other stuff to short out what year is the car what kind of car
Dec 01, 2010 | Pontiac Grand Prix Cars & Trucks
Machine lets a little water in then stops,this repeats a few times then stop alarm goes off
Hi just read your posting.Just a couple of questions. 1 What is the model number of the machine? 2 When the alarm starts there will be flashing lights.They will be in a row of 8 lights.Starting from left to right which ones are lit,Is it the 2nd and 5th or the 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.
Jul 23, 2010 | Fisher and Paykel Washing Machines
When i switch on my fisher an paykel smart drive model gw601-f, all the lights come on for a few seconds, then just the top lights flash back and forth
Hi just read your posting.Please reply back and tell me which lights are flashing.This is an Error Code and it will let me know what is wrong with your machine.On the row in which the lights are flashing ,starting from the left to right which ones are flashing,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply back with additional information on the lights and I am sure I can help you rectify this fault.
Jul 21, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a Fisher Paykel Model GWL 11 washing machine. A couple of days ago the machine was operating, but when it came to the spin cycle it would not enter the cycle. It kept trying, but eventually let out...
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Jun 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Uneven bottom stitches that ball up every 4th or 5th stitch
Have you threaded the bobbin correctly? If it is in the wrong way it will do that. Hope this helps.
Mar 08, 2010 | Sewing Machines
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Dishwashers Logo
52 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
