Question about Refrigerators
Why is the fan making a terrible loud noise when I first turn it on....it is 3 years old?
    Top Expert:
  • 6,702 Answers
A blade came of? a bearing is defect, dried out or dirty? the the blades are hitting the casing? to name a few posssibilities. You should investigate yourself, or consult a tech. Impossible to make a correct guess, when I can't see or hear the fan working.
Posted on Mar 30, 2015
Testimonial: "It works and stops when it gets to right temp but it sounds terrible.. the fan is spinning and blades are working"
My Juki HZL F300 bobbin case is making a terrible noise. It sounds like the bobbin is going to spin right out of it. This noise is SO loud! Do I need to oil anything? It is not even a year old.
Try installing a brand new needle. Sometimes a bent or dull needle will cause lots of racket.
You should consult your owner's manual for maintenance--cleaning and oiling instructions. Most sewing machines do require oil--some more frequently than others. Most machines also need frequent oiling in the bobbin/hook area. Be sure to use only good quality sewing machine oil for your machine--NO 3-in-1, WD-40, cooking oil, or old brown stinky oil.
If it continues to make the noise, you should probably have it serviced. Since it is less than a year old, it might still be covered under warranty, so don't delay.
May 31, 2016 | Juki Sewing Machines
My Leisure HJA6100 icemaking unit is making a terrible noise, which stops when I open the freezer door. It's just a year old, what could be causing this noise?
Your evaporator fan motor would be the cause of your noise. Yes, it can be repaired, just need to replace the fan motor. The noise stops when you open the door because the fan motor turns off when the door is open.
Mar 13, 2013 | Refrigerators
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
We have a 3 yr old 2hp waterway pool pump that is making a very loud noise. It is still working but the noise is constant.
I have a 3 year old pool pump, waterway. I can hear the motor humming but the fan wont kick on. I pulled all hosed to make sure they were cleaned out. Any ideas why it would be froze up?
May 08, 2011 | Sport & Outdoor - Others
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
3 year-old Goodman compressor/heat pump terribly loud @ start
Without being there to see it and have only your description in front of me, it sounds like the fan blade could be out of balance.......but it sounds more like a loose fan blade hub. Most Goodman units offer a minimum 5 year parts warranty. The Labor warranty is questionable, but the installing contractor or the Goodman Distributor should be able to give you that information. Of course this would cover manufacturer problems and not physical damage. As far as a history of this problem with Goodman..........I've seen it with every brand. If there is a problem getting it under warranty, you might be able to purchase the blade yourself. Before replacing the fan blade, I recommend disconnecting the motor wires from the contactor, tape off the ends and remember exactly where they were attached.....then start the unit to see if the noise is still evident, if so, it's probably your compressor. I recommend a certified repairman....not the one that quoted you $800.00. If you hear only the compressor start up and not the loud noise you are discribing, then try replacing the blade first.
I hope you find this information to be very helpful to you. :-)
Mar 16, 2010 | Goodman CKL60AR60 Air Conditioner
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
Noise exhaust fan on my Amana AOCS3040
The exhaust fan on my oven (Aosc3040) is loud also and has always been. Just hope nothing significant brakes because this model has been discontinued and it is difficult to get parts for it. I have been told by Amana that the life expentency of this oven is 10-13 years, so don't invest in anything that is not necessary. The glass door broke on mine and I cannot get a replacement piece. My kitchen looks terrible. It is a shame because the oven works great. Linda
Oct 06, 2008 | Amana AOCS3040 Electric Single Oven
Loud Fan Noise
Usually the fan on graphic card dies first. It can be replaced with another one but I'd suggest you to build in 80 or 100 mm fan to blow directly on your graphic card cooler. Remove the lid and check if perhaps some cable has fallen close/into fan blade. It must be one of those two. I'm 90% certain.
Apr 23, 2008 | E-Machines eMachines Desktop PC
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
