Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
How do i fix motherboard cmos problem?
I cant turn on the computer unless i reset the cmos.. by using jumper.. when i restart the computer, it displays nothing and the power led and hdd led won'nt light up except the cpu fan.. the only way to turn it on is to reset the cmos again.. how could i fix this? thanks
    Brigadier General:
  • Biostar Master
  • 3,400 Answers
REWIRE ALL ELECTRICS BY THE MANUAL.
CHECK BIOS BATTERY
http://www.pcityourself.com/building/frontPanelConnections.php
FRONT PANNEL CONNECTIONS IN GENERAL.
Posted on Mar 30, 2015
Testimonial: "i've rewired it already and changed changed the cmos, but nothing happened..."
    Top Expert:
  • 6,702 Answers
Don't forget to replace the cmos battery. Most of the time it looks like a quarter or a dime. It is a lithium battery and after you renewed it, it should last at least 5 years.
Testimonial: "i've already replaced it with a new ones .. but still the problem exists.."
    Top Expert:
  • Biostar Master
  • 10,875 Answers
Install correct bios for your motherboard
Biostar Motherboard Driver Updates
Bios password for foxconn h61mxe
open up the case and look at the mb, look for cmos reset, you need to turn off the computer use the jumper to short out the board, when the jumper is in place turn the computer on let the system boot up than shut the system down remove the jumper, restart the computer.
if that fails you could try removing the back up battery on the board.
maybe try removing the battery on the motherboard first before resetting the cmos.
Feb 27, 2015 | Foxconn H61MXE-V...
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Got a dell latitude e6400series forgot bios password can i fix this problem ?
Welcome to Fixya
Common procedure in resetting the password is by resetting the motherboard by reseating the CMOS battery. You need to access you motherbard and locate the circular silver metallic object on the motherboard. This is much bigger in size compared to a wristwatch battery. CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. Put the the battery back in and turn on the computer.
Other procedure is the jumper reset. Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
If procedures above has been done and yet you are getting same results. Its time to call you manufacturer and have the motherboard re-flushed or re-imaged.
Thank you for using Fixya!
Mar 31, 2011 | Computers & Internet
I changed some BIOS settings for CPU speed and memory, now it wont boot - how do i reset the BIOS back when I cant get to the BIOS screen? Soyo K7V Dragon motherboard
Hi:) Turn the computer off but leave it plugged in so you have no static problems. Open the computer tower and on the motherboard near the Cmos Battery there is a blue or red jumper that covers 2 of 3 pins move it to the other side of the 3 pins for 30 seconds then put it back that will reset the bios to default.
Mar 07, 2011 | Soyo SY-K7V Dragon Motherboard
How do you get the password off of the
There are two ways to reset the boot or the bios password:
1.By removing the CMOS battery
You have to shut down the computer , disconnect the power plug and open up the unit and locate the CMOS battery ( which usually looks like a coin) . Carefully lift the battery out of its socket and set it aside.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
2. By using the motherboard jumper
Shut down your computer and disconnect the power plug. Identify where the jumpers are located. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. Then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down! Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.
For detailed instructions and snapshots u can check up this link :
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Mar 15, 2010 | Computers & Internet
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Reset Cmos Settings for Acer Computers
There might be a jumper on your motherboard that's labelled CMOS, or reset... you just have to move the jumper to the other pin combination, power up your PC, then turn it back off and replace the jumper.
If you can't find a CMOS jumper, try unplugging your computer and removing the battery on your motherboard for a few minutes. When you turn it back on, your CMOS should reset to factory defaults.
May 07, 2009 | Computers & Internet
Wont startup
1.may be the smps(power supply) not be proper.check power supply......
2.processor may be corrupted
3.bios cell may not be working proper
Dec 15, 2007 | Intel Motherboard
Computer won't boot
if you want too boot your computer when you start computer thne click delete click one or more time and setting screen available. set first boot cdrom option select.. and save satting. and restart. then you are cdrom open and put bootable CD in cdrom and restart computer see bootable your computer..
i hope to thankfull to you..
Dec 01, 2007 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
97 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
