Question about LG Washing Machines
My LG machine shows dE as soon as I start it. The lid is closed. What to do?
  • LG Master
  • 2,160 Answers
De = door error
It might just be a malfunction. If the code appears mid-cycle or at the end of the cycle, power off the washer and unplug it. Wait for five minutes before plugging it back in. Power it on and see if the door latch releases. If it doesn't, service will be required.
An item may be caught in the door. Unplug the washer and wait five minutes before plugging it back in and turning it on. If the door still doesn't unlock, the item could be pushing on the door and preventing the latch from unlocking. Service may be required.
Is the door or gasket damaged in any way? That may prevent your washer from latching or locking, resulting in a DE error code. Check your warranty policy to determine coverage under the manufacturer's warranty.
Posted on Mar 31, 2015
  • LG Master
  • 2,210 Answers
Check the owners handbook if you have it. If not go online to the main LG website find manuals and download one. Have your model and serial number ready, these are on a sticker on the back.
Posted on Mar 30, 2015
  • 6 Answers
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Posted on Apr 12, 2009
  • 5 Answers
SOURCE: The small metal piece on the lid rusted and broke
You can bypass the switch by jambing something in there and this will allow it to spin with the lid open or closed but please keep the lid closed at all times while washing.
Posted on Oct 31, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
  • 6277 Answers
SOURCE: Model WFT65A31EC washing machine. Problem
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on May 29, 2011
  • 360 Answers
SOURCE: I have a LG topload
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Posted on Sep 22, 2011
Lid open DE error in WF-T6517TE
This is lid magnet peice came out or lid assymble not fixing properway.
Mar 13, 2014 | LG Washing Machines
My washing machine LG WFT type showing dE error. understand it is door error. I want to know where the door switch is located.
You're correct- 'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor. Both are behind where the door's latch goes requiring a service engineer's attention I suggest ;-0(
John C
Jul 19, 2011 | LG WFT1071TP Top Load Washer
My WF-T1340TP washing machine is doing all process that inculeds waterpumping and draining but it is failing to wash.On the desplay pannel it shows that dE which meanse according to the manual the door...
'de' does indeed stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
John C
Jul 14, 2011 | LG Washing Machines
My fuzzy logic turbo drum WF-t1340tp machine is getting a de error message. The machine start quite alright, and start to move but only for a while, then it shows the de error message. What is the...
Door Error. Could be that the lid gets bumped open while washing. Make sure it is secure, or it could be a loose connection on the wiring of the door switch itself. This feature is used to prevent small children from sticking their hands into the machine while it is operating, it switches of the working components as soon as an interruption is made with the Door switch.
Hope this helps.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | LG Washing Machines
I have LG WFT70A37ECT top loading washing machin. getting dE error even though door is close, what is the other reason
How many years is yoru washing machine? I suspect bthe magnet on the lid of the washer has probabkly come off which causes the washer not to identify that the door is closed. U need to replace a magnet on the lid.
Oct 17, 2010 | LG WM-1480FHD Front Load Washer
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
Sep 09, 2010 | LG WFT1071TP Top Load Washer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Sep 11, 2009 | LG Washing Machines
Washing Machines Logo
187 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
