Question about Thermador SC302T Electric Double Oven
Convection/Conventional in same unit SC302ZS
We have a Thermador SC302ZS convection/conventional oven where only the conventional settings of the oven work; it will pre-heat, bake and the fan operates.
The "convection" settings do not work. The pre-heat will only display 100*f, the fan rotates, but the oven will not heat.
Thanks, Sonoma Oven @ Thanksgiving!
  • 290 Answers
Re: Convection/Conventional in same unit SC302ZS
If this oven works the same as the 302T, the bake element is not used during convection mode, only the convection element.
The cooling fan must come on
The air switch must close
The convection element must be good
I would suspect the element first.
Post back and let me know what you find out.
Posted on Nov 16, 2007
  • 537 Answers
F the oven doesn't heat and the on-off light works, test the appliance controls, motor,
and heating element .
Posted on Nov 15, 2007
0 characters
3 Points
I self-cleaned the convection oven on my sc302tw, and now it does not heat on any settings, convection, bake or broil. It is 14 years old.
Looks like the sensor has tripped... on my Bosch oven, I opened the back. Connected to the thermostat is a switch with a little button which pops out to prevent the oven from overheating... push in the button to reset it and it should work
Nov 06, 2013 | Thermador Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
The convection oven feature does not work. The oven heats (slowly) as a conventional oven but when we set the oven for convection the oven does not heat.
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more than this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Nov 25, 2011 | GE Profile JT915 Electric Single Oven
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
What brands of aluminum foil are safe for convection ovens
Any good quality heavy duty foil should do. Temperatures in conventional ovens never come near the melting point of aluminium, although all aluminiums for a slight health risk.
Jan 16, 2011 | Whirlpool Ovens
Stoves new home fan assisted oven. do you reduce heating time and or temperature
It is usual to reduce temp and or time for a fan assisted oven, as opposed to a conventional convection oven.
Please rate my solution.
Nov 24, 2009 | Stoves Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
I need to self- clean my Thermador convection oven
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
thank you,
please don't forget to rate our answers.
Feb 19, 2009 | Thermador C272 Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
693 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Thermador Oven Expert? Answer questions, earn points and help others
