Need password for belkin.5d2 - Computers & Internet
Need password
Connect the Belkin router to a computer with an ethernet cable
Open a web browser and enter 192.168.2.1 in the address bar.
Check the Network name and Password - make a note of them.
Setting up the Belkin router
Belkin
N150 Wireless Router
Part # F9K1001
Belkin
Feb 18, 2014 | Belkin Connect N150 Wireless N Router
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
Hello i need drver for ev1938-4ch for windows 7 alienware please help
hi,
You will find the solution,if you browse the following link
www.drvbase.com/5d2/all/ev1938-4ch-driver-windows-7-64
May 27, 2011 | Office Equipment & Supplies
How do you set up a password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Feb 27, 2011 | Belkin Surf N300 Wireless Router...
I forgot my password for belkin f5d7231-4
Do you mean the password for the wireless network or the password for the router. If you don't know the wireless network key or the password then you will need to access the router set up and you will find the wireless password there. If you don't know the password to access the router then you will need to reset the router and reconfigure the router. Click Here for step by step solutions
Nov 16, 2009 | Belkin (F5D7230-4) Router (587009)
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Jun 26, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
