Question about Lands Phones
My phone rings, when I pick it up i can hear it ringing in the background, when I put it down it continues to ring. I have bought a new phone with the same result
Telephone with fault is 01646 603962. My mobile is 07548 795784.
  •  johnny rebel
    johnny rebel Mar 30, 2015
    Hi Penny Gomm, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?turn off speaker phone?? make and model?
  • 4 Answers
SOURCE: number of rings
Sounds like you have either send all calls (SAC) enabled or your station is call forwarded to voicemail.
Disabling send all calls or call forward (as applicable) will solve the problem.
Posted on Apr 03, 2009
consultel1
  • 860 Answers
SOURCE: The phone rings 3 times and goes to voicemail on
I don't think its a good idea to back the vms cover rings to 8. The furthest I'd go is maybe 6.
Changing the VMS cover rings on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#321"
the display should say VMS Cover Rings and ask for an extension number
enter the extension number you wish to change
The current ring data should be displayed
enter in new data (8 ring if you wish)
press feature "00" to logout
Posted on Dec 10, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
issikiki
  • 563 Answers
SOURCE: Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
Posted on Jan 26, 2010
  • 17 Answers
SOURCE: Phone rings only once then is silent. How do we
This is a symptom of a feature that has been activated. It could be the call is forwarded, it could be the voice mail is programmed to pick up on the 1st ring. On some systems ext's can be programmed to ring elsewhere after a set number of rings. The do not disturbe feature could be activated. If it is an outside line, call it from your cell and see what you get (voice mail-continious ring-another ext etc.) Find out if it does it on an in houes intercom call. Look for a DND button the phone...is it lit up? Does the display show calls forwarded or DND? Hope this helps. Good luck.
Posted on Mar 24, 2010
Hi, one of our Call Center workers cannot hear the ringing phone when she has the headset onWhat's your problem?
The ring from the telephone is picked up by the internal microphone on the HL10 Handset Lifter, typically for most phones, the lifter sits directly over the speaker grill on the telephone where the sound comes out. For telephones that curve out on the left side and don't have a straight edge, there is an accessory called a "Ring Detector" which is used. Here's a link:
HL10 Nortel Adapter Kit - 46780-01
If the internal mic on the lifter has gone out, you can plug the ring detector into the handset lifter and just stick the ring detector over the speaker grill to pick up the ring. Plugging this into the lifter will bypass the internal mic, this accessory would have come with your HL10 lifter. You can also check the ring volume on the telephone, and you can also try adjusting the ring tone on the phone (sometimes it will pick up one ring tone better than another). Here is a link below if you need to order a new ring detector:
HL10 Nortel Adapter Kit 63014-01
Good luck from Headsets Direct!
Oct 27, 2011 | Plantronics PL-CS55 Wireless Headset
We are unable to turn a ringer on, for when the general number rings, on one Mitel 5020 IP Phone, and we would like to make it so another phone doesn't have to hear the ring on the general number ring.
This is set on the buttons for the phone from within the system programming. Individual buttons can be set to NO Ring, Ring, Ring Continuous, Delay Ring, or Delay Ring Continuous.
Continuous meaning that even if you are on the phone, it will ring audibly on your phone. If it's not set to continuous, it will only give a blip.
You should contact your vendor for assistance in setting this up.
Aug 03, 2010 | Mitel 5220 IP Phone
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Mar 04, 2010 | Uniden DXA15588-2 Twin Cordless Phone
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Phone won't ring with incoming calls
Jun 02, 2009 | Lands Phones
BROTHER FAX 1840-C.
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
Ring Tone Won't Stop
I had this problem with my old phone, it was a Samsung Sch-950 I recently upgraded my phone and new phone doesn't do it so I don't have an answer other than to get a new phone.
Oct 26, 2007 | Motorola Mobility H350 Wireless Headset
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
