Question about Plumbing
I have a 2 handle bathroom faucet. I replaced the spring and seat in each by taking off the handle and taking out the cartridge and then swapping in a new springs and seats. I put the same cartridges back in, tightened the nut and put the handles back on. Now water is coming out of the faucet full blast whether the handles are in the on or off position. I can't figured out what is causing this. I put everything back together in the exact same way. And advice to try something would be great!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
Make sure you replaced the actual washers at the bottom of the stem & in the correct size.also, before you put the stem back in,make sure it's all the way in the open position( when installed,but before you turn the water on,you can put in the close position. the washer will then hit the seat & not allow water to run until you turn it on)
Posted on Mar 30, 2015
    Top Expert:
  • 3,698 Answers
Cartage(s) may be either backwards or switched with each other.
Other possibilities the spring got out of place.
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
SOURCE: Water suddenly stopped flowing from faucet.
This happened to me just tonight, "slam" and all on a Delta 470. The gasket that leads to the pull-out hose corroded and finally slipped free, lodging itself in the hose. Just pull off the hose by removing the plastic clip, then pulling on the hose with a good tug, it should come free. The destroyed gasket was sitting right in the connector in a perfect spot to block the water any time it was turned on. This particular gasket is a "second layer of defense" gasket, but even though the faucet probably won't drip without it, you should probably still replace it.
Posted on Apr 15, 2009
  • 15 Answers
SOURCE: Moen one handle kitchen faucet very low water stream
if the pressure is good with the head off then you can probably get a new head for it u shouldn't have to change the cartrige. it sounds like the head is clogged so plastic pieces in the head to help save water "water savers" it is hard to clean them i would try changing the head u should be able to find on for a moen, u buy for looks u buy it for life. take the old head with u when u go to buy a new one so they can match it up to the right one.if you can't find it and a lowes or home deptm try a plumbing supply house
Posted on Apr 19, 2009
  • 62 Answers
SOURCE: when I installed my delta replacement cartridge
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Posted on Jul 11, 2009
snap101
  • 117 Answers
SOURCE: I just installed a new cartridge in a moen single
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Posted on Jul 29, 2009
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
My cold handle on a montecello faucet turns freely, however, nothing happins I have no cold water. What do I do?
First check that the handle is tight. If yes take the handle off and turn on the water buy turning the stem without the handle if you still do not have water remove the stem and cartridge and see if you have water if yes clean or just replace the cartridge. If the faucet in old replace both.
Mar 15, 2011 | Moen Bathroom Sink Faucet - 4-inch...
I have 5 of these faucets in my home that was built only 2 years ago. All of these faucets leak from the spout. I have replaced cartridges and they still leak.
Did you replace the seats and springs under the cartridges, Delta part number RP4993. These are the more important parts to replace when your Delta faucet is dripping from the spout.
Sep 03, 2010 | Delta Faucet 2578LHP/H277 Leland 4''...
How do I replace the spring and rubber seal
First turn water off to faucet and remove the screw that hold's the handle in place. They may have a cap on the handle to remove to access the screw.
After screw is out the handle should come off you may have to wiggle it a little to get it to come loose. Next you will have access to the spring and washer for that stem.
It should be located on the bottom of the stem just remove it and replace new ones back in place.
Some have sping's and seat in the body of the faucet if not located on the bottom of the stem.
Jul 13, 2010 | Delta Faucet 2530CBLHP/H25 Innovations 4''...
Trying to replace rubber washer and springs in Delta single ball lavatory faucet. I seated the plastic top into the metal notch but, after tightening and opening the valve, the water does not run--after...
When diagnosing faucets, I always start at the discharge end. Remove the aerator and try to run the water. If you get water flow, then the aerator is clogged with some junk. If not, take apart the faucet ball again and make sure the rubber seats are seated correctly. Reassemble the handle and try to turn on the water. If that does not restore flow, remove the handle and carefully turn on the shut off valves below the sink to check for flow. Get the idea?
Apr 13, 2010 | Home
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I have replaced the stem valve in my innovations two handle faucet but now the water will not shut off completely.
Remove it and make sure that the cup washer and spring are seated propoperly. The large end of the cone shaped spring sits on the bottom of the housing seat and cone washer slips over the small end of the spring. Use the shank of small screwdriver to guide the washer and spring by placing them on the shake in the proper order and then putting the shank into the housaing and sliding the washer and spring.
You may also have to disconnect the supply tube that connects to the faucet under your sink. This is to relieve the pressure within the valve housing which can cause the washer to become mis-aligned when installing the cartridge
. Also check cartridge for defects and make sure you have it install in the correct position i.e you may have to remove it rotate it 180 degrees re-install it and move the limit stop (if it has one, depends on year) inserted in the top to the correct side for propoer operation direction of the handle after you reverse it.
Hope this helps, sincerly T. Wood, C&F Enterprises, A Plumbing Contractor
Oct 07, 2009 | Delta Faucet 2530CBLHP/H25 Innovations 4''...
How do I replace the stem in a two handle faucet after replacing the spring and rubber seat? I don't know how the two plastic pieces should be inserted.
There are tabs in the cartridge and slots in the faucet body, line them up and push. If the handles turn incorrectly, turn the cartridge 180 degrees.
Aug 30, 2009 | Delta Faucet 2530CBLHP/H25 Innovations 4''...
Need technical diagram of single hole faucet
Not sure where to find the diagram, but what type of faucet is it and where is it leaking? It it's a single lever, remove the hot/cold indicator to uncover an allen set screw. Loosen it and remove the lever, then the outer bushing nut. Now you'll have access to the interior parts around the cartridge (make sure you turn the water off to the supply lines before proceeding further). If it's the two handle type, remove the index buttons from the top of each handle to uncover a screw with either a slotted or phillips head. Remove the screws and remove the handles. You now have access to the valves and seats. If it's a 12-year-old faucet, the o-rings and seats will probably need to be replaced and this will fix your problem. If it's a single lever type, you'll need to replace the seats and springs and it will probably solve the problem.
Jun 14, 2009 | Grohe 40367000 Chrome Accessories Single...
Plumbing Logo
119 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
