Question about Ricoh Office Equipment & Supplies
My Ricoh Aficio 3035 indicates the used toner bottle is full. I replaced the transfer unit, controller board, main board & I/O Board but the problem remains. How do I solve it?
  • Ricoh Expert
  • 155 Answers
You did a lot just need to ask did you empty the waste toner bottle.
Posted on Apr 06, 2015
Scott Ellin
  • 558 Answers
SOURCE: ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Posted on Sep 20, 2008
chad7houston
  • 62 Answers
SOURCE: Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Posted on Oct 09, 2008
  • 9 Answers
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Posted on Apr 08, 2009
SOURCE: used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Posted on Sep 14, 2009
  • 903 Answers
SOURCE: ricoh aficio Aficio 3224C used
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Posted on Mar 21, 2011
Used toner bottle is full
I'm going to assume you typed the model wrong, and that it is a 1035 like the header states. If this is the case, the used toner on these is inside the transfer belt unit.
Open the duplex unit if equipped, then open up the right-side door. Attached to the door is the transfer belt unit, as see below:
602d8058-7b67-4449-895f-e01b266fd371.jpgLift the lever as shown, then lift unit out of machine. There is a panel with 6 screws near the bottom of the unit, remove all 6 screws and remove the cover. Be very careful, this thing is going to be FULL of used toner, and will make one HUGE mess if not disposed of properly. Once emptied, put cover back on, re-install unit, close doors, and you should be good to go.
Jun 09, 2013 | Ricoh Aficio 1035 Copier
Ricoh aficio 2105 waste toner full indicates even if it was already empty, cleaned the bottle sensors still indicates full, how am i going to reset it?
Make sure the 2 waste toner are empty.
You have 2 bottles of waste.
1- Next the papaer trays
2- Next the development Unit
May 25, 2011 | Ricoh Aficio 2015 Copier
Where is the trasfer unit on a Ricoh 3035 I have a message that says used toner bottle is full.....solution is to empty the transfer unit.....where is the transfer unit?
when you open the right door, the transfer unit is "brown belt", you need to remove it from door, remove belt, remove the screws and plastic cover and vacuum or clean the waste toner.
Hope that helps!
Apr 12, 2011 | Office Equipment & Supplies
The used toner bottle is full. Where is it
Open the right door,remove the transfre unit,remove the transfre belt unit.The waste toner collection bootle is located under transfer belt section.Remove 3 srews remove the case and use the vacuum cleaner to clean the waste toner empty.
Nov 24, 2009 | Ricoh Aficio 2035 Copier
USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
May 06, 2009 | Ricoh Aficio 450 Copier
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
162 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
