Question about Garden
Where can I buy a JCB mower blade?
Can't fine any EM1740RF blades anywhere
    Top Expert:
  • 3,698 Answers
Http://www.oregonproducts.com/pro/lookups/selguide_bladelookup.aspx
Posted on Mar 30, 2015
Where can I purchase replacement blades?
Hi Jim, you can buy replacement blades for your riding mower at most hardware, or lawn and garden store. I believe Sears home and garden has them also. They are the same as a regular push mower blade, but smaller because you have 2-3 blades. I'll put a link to help you out. All you really need is the model of your mower, and blade length.
Sears com
Aug 17, 2015 | Garden
Yardman troubleshooting
More than likely the bearings on the mower deck that your lawnmower blades bolt to are seized or are close to it .Disconnect the negative battery cable from battery before you get anywhere near the underside where the blades do there business. Better yet, remove battery completely, and have it tested at AUTOZONE for free. While battery is out , check free spin of deck blades. Any resistance or grinding while blades are disengaged >debris , fence wire , rope tarp, etc.. or bearing failure. [DUE TO THE NATURE OF THIS PROBLEM AND THE POSSIBILITY OF SERIOUS INJURY, I WOULD STRONGLY RECOMMEND TAKING IT TO BE CHECKED AT INDY SHOP. ... ALTHOUGH COMMON SENSE WILL GO FAR IF YER MECHANICALLY INCLINED. .. YOU TUBES VIDS ARE A GOOD STARTING POINT. NOTE:BEARINGS CAN BE REPLACED,, WHEREAS A HAND OR A FOOT ...AINT AS EASY. Good luck
Mar 21, 2014 | Garden
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What holds mulching blade to lawnmower?
A nut.
Unplug the spark plug.Lift the mower.Under the mower you will see the blade.It is held on buy the nut in the center of the blade.Wear a leather glove(or something similar)to hold the blade and turn the wrench(socket&ratchet)with the other hand.
Jul 12, 2011 | Arnold Corporation Arnold 21-Inch...
I RECENTLY BOUGHT A PUSH MOWER AT A FLEE MKT..NEVERNHEARD OF A QUATTRO MOWER...IT HAS A 22 IN BLADE..I HAVE AN OLD 21 IN BLADE FROM A L-BOY..CAN I USE THAT ON THIS MOWER OR MUST I BUY NEW 22 IN BLADE ???...
i just looked up Quattro mower they are a 4 stroke engine and yes i would buy a 22 inch blade but be sure it fits this mower PS go to wall mart and check out their blades they are reduced now.
Sep 09, 2017 | Yard Machines 158cc Push Lawn Mower #11a...
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
MTD bsgger/Mower 21 self propelled only number 1183AC.Need part that mower blade is attached to then to drive shaft. Can't find
Hi and welcome to FixYa. I am Kelly
The part your looking for is called the BLADE ADAPTER. The part number should be: 753-0588
These are available at most any lawnmower repair / parts store. If you walk in woith what is left of your old one they can sell you an exact replacement. I am kind of old school when it comes to blade adapters. I always match old with the new before I buy them. I have been burned too many times from on line sites mainly with blade adapters. Most anything else available on the net is fine.
Here is a whole page of adapters:
http://www.lawnmowerpros.com/MTD/MTD-Blade-adapters.asp
Thanks for using FixYa.
Kelly
Apr 02, 2010 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
