Question about GPS
What is the maximum capacity of a micro SD card compatible with my GPS?
  • Thomas Smithbrother Mar 30, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    make and model of your GPS.
  • Anonymous Apr 01, 2015
    GPS is Mediatek MSB 2351 800Mhz. I need to know which Micro SD (4, 8,16,or 32 Gig)is supported
  • 4 Answers
SOURCE: Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Posted on Aug 24, 2008
  • 59 Answers
SOURCE: Micro sd card not showing up on the gps
Have you got GB Discoverer on the card? The map should appear on the Map Information list in the Setup > Map area. Double check the placement of the map card. Also, in case you have not found it yet, there's wealth of information on the Oregon Wiki here: garminoregon.wikispaces.com
Posted on Nov 04, 2009
  • 547 Answers
SOURCE: downloading songs from an i-mac computer to a garmin zumo 660
I don't know for sure, but most likely the problem is that iTunes keeps songs in AAC format, and the Garmin wants them in MP3 format.
If that's the case, then what you need to do is this:
in iTunes, build a playlist of the songs you want to export.
Click on that playlist to show the list of songs
Click on the first song in the list, then hold SHIFT and click on the last song in the list so they're all highlighted.
Select the menu option "Make and MP3 copy". Apple keeps moving this option, so you may have to hunt for it, depending on the version of iTunes you have.
This should leave the nice-quality AAC versions alone, but also make MP3 copies of each song.
Copy the MP3 files to the SD card and try that in your Garmin.
Posted on Jun 06, 2010
  • 747 Answers
SOURCE: will not recoginize upro gps micro sd card shows
try connetecting your gps on windows trouble shooter.
Posted on Feb 05, 2011
sharcnet
  • 2130 Answers
SOURCE: micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Posted on Apr 08, 2013
Binatone Homesurf 744 - put in micro SD card but nothing will save to it although it says it is there (can unmount it).
Please make sure the capacity of your microSD card is not larger than the maximum card capacity allowed by your device. For example, if the maximum card capacity allowed by your device is 16 GB and your card capacity is 32 GB, your device may not recognize it. And is the "unmount SD card" option grayed out or solid ?
Hope this helps.
Dec 16, 2014 | Cell Phones
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 | Cameras
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
Micro SD Capacity
The e260 will not recognize any microSDHC cards. It will only use microSD cards, which are limited to a maximum of 2GB in size.
Apr 14, 2010 | SanDisk Sansa E280 MP3 Player
I just insert a 4G micro card and says card error. Everything else works fine for 3 years ( never put a sd card before ). Thank you in advance Miguel
Check your mini SD card and see if it has the SDHC (high capacity) logo on it. Originally SD cards, including the mini SD, had a 2GB limit by protocol. The DC10 was introduced when this was the most advanced protocol. Since then the SDHC protocol has been introduced, but the DC10 is not compatible with SDHC. You need to get a mini SD, 2GB maximum capacity.
Mar 16, 2010 | Canon DC10 DVD Camcorder
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Maximum SD card size for TomTom ONE XL
The XLS which is not that much different and supports 4Gb as used in mine which allows me to keep maps of the US,Canada, UK, and the whole of europe on it and swap at will. I bought a cheap generic one. I do kow that those cards that use micro sd can and do have problems so best to avoid the micro type unless your device takes those specifically
Nov 29, 2008 | Tomtom ONE GPS Receiver
Compatibility of sdhc card with konica milota Dimage Z10
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Nov 28, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
My phone NOKIA 6300 could not find micro SD card. please what do i do?
If it is a 4GB micro SD card it won't work, a nokia 6300 doesn't accept HC (high Capacity) micro SD cards. Maximum you can use is a 2 GB micro SD card.
Don't forget to rate, thks
Oct 28, 2008 | Samsung SGH-D900 Cellular Phone
GPS Logo
61 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
