Question about Cameras
When i switch it on it just bleeps & i button flashes red. treid to put it on cotton mode it wont move when you press up arrow
  • Thomas Smithbrother Mar 30, 2015
    Hi Jerry Sajoe, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    make and model?
  • 28 Answers
Dear!
What is your camera mode?
Posted on Mar 31, 2015
B&d control a door mpc2 model not opening control panel has flashing green up down light and also flashing red light limit set
Check your user guide if available. It sounds like you haven't set the door open limit, so press the up arrow & fully open to the door & push set, do the same for the down arrow until door is completely closed. Push the set button again & the door should be right..
Apr 19, 2016 | Building Materials
How do I set the digital time in my Surface 31874 watch?
When you press the Mode button:
1st press: FRI, SAT, SUN arrows flash. This is chronograph mode. Use START/STOP for stopwatch and RESET for split/clear.
2nd press: MON arrow flashes. This is where you set the alarm. Use START/STOP to advance number, and RESET to switch between minute and hour.
3rd press: TUE arrow flashes. This is where you set digital time. Seconds (in analog time window) flash first. Use START/STOP to reset seconds or advance number, and RESET to switch between seconds, minutes, hour, date day, and date month. Press mode again to exit. Have fun!
Oct 19, 2012 | Watches
Kx-dt333 phone rings, red light flashes but no ringer sounds ... ringoff is displayed on screen how do we switch to ring mode?
You can press the softkey under RingOff and the up arrow on the Navigator button, or just press the up arrow on the navigator button two times. The display will show the ringer volume level as you continue to press the up arrow.
Carl
Oct 26, 2010 | Panasonic KXDT333 Phone
PLaystaion is broken it flashes red then i turn it on and it goes red then it goes blue then yellow and then beeps and goes back to flashing red and it wont turn on
hello have you tried a reset ,press and hold the standby button on the front of the ps3 you will hear 1 bleep the 2 short bleeps after the short bleeps release the button hope it works
regards
shaun
Oct 24, 2010 | Sony Playstation 3 (PS3) Console
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
How do i key in the code to my radio i have the code it an audi concert radio 1998 a4 thanks
Once you get the zeros on the display use the up arrows to increase the first digit to the first number of the code then use the right arrow to move to the second digit and continue until you get all digits in then press the mode button for 3 seconds until it bleeps and switches on
Aug 27, 2010 | 1996 Audi A4
When I turn on the PS3 it makes loud driver noise and the blue /green lights come on but after 30 seconds it beeps 3 times and flashes red. There is no orange or yellow flash. Someone suggested taking out...
hello have you tried to reset it.while in standby mode press and hold the power button you hear 1 bleep then 2 short bleeps release the power button this should reset the ps3 make sure you've got it connected to the tv screen hope this helps
regards
shaun
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
Can one switch off the 'bleep' on the Fuji AX280? Manual is less than helpful!
1. Press central "Menu/OK" button.
2. Press LEFT arrow (the one with the flower/close-up icon).
3. Press DOWN arrow (display reads "SET")
4. Press RIGHT arrow.
5. Press UP arrow until you reach "OPERATION VOLUME".
6. Select preferred loudness level.
Done.
Jun 25, 2010 | Fuji Rod Repair Kit
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Mar 11, 2010 | Pioneer VSX-1019AHK A/V receiver
580 ex speedlite
Turn on flash while pressing some of those buttons with good batteries
Try switching from Meter to Standard Mode and move head around.
Try move the flash head(flash tube) in Manual mode.
It's in electronic locked up because you're moving that flash tube zoom too much. 98% of photographers use that mode:-(
Alexander
atdlee@netzero.com
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
