Question about LG Heating & Cooling
I have put d 60 size and 33 inches but not succes
Capillary size and length in .75 split ac of lg
5 Suggested Answers
  • 95 Answers
SOURCE: i installed a dual split
Post a little more information and by the way are you certified to handle freon? $10,000 fine if you are not.
Posted on Jun 10, 2008
sodeep
  • 3267 Answers
SOURCE: LG DUCTABLE SPLIT TYPE A/C PROBLEM
what you have left out is the thermostat and they relays(electrical) which are activated by the thermostat. Another point is the door closing button near the bottom right side mounted on the body of the fridge. Check it out too.................................sodeep
Posted on Jul 26, 2009
  • 21 Answers
SOURCE: lg 1.5 tr split ac capilary replaced.size 5.0
The best practice when replacing a cap tube is to replace it with the identical size and length of the old cap tube. Also, you must run it in the same way, if the cap tube was soldered to the suction line in any area then the replacement should also be soldered to the suction line. The old cap tube should have been stretched out, measured and gauged with a cap tube gauge. If you just went by load, it appears your cap tube is the wrong size, should be a #4 or .064ID and not a #5 .028ID. This is just based on some cap tube sizing charts I looked at assuming you have a single cap tube and not a multi circuit evap. Other than the cap tube the symptoms point to a system that was overcharged, dirty condenser, condenser fan motor not running. If you have a way to check suction and discharge pressures this will be the best way to see what is going on.
Posted on May 10, 2014
239gatorac
  • 1929 Answers
SOURCE: 1.ton ac capillary pipe size and length I want to know. B coz suction line cooling level is very low gass psi 75
I'm guessing you should have 3/8 & 5/8 copper on that unit with a maximum of 50 feet. I doubt the line set size is affecting your pressures that significantly, you likely have a leak.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on May 05, 2017
May 05, 2017 | Heating & Cooling
Lg 1.5 tr split ac capilary replaced.size 5.0 ,length 1 1/2 ft. gas charging done.ac running for 20 mints.after 10.7 amps incressing and of the compressor over heat.i will replaced 50+4 running...
May 10, 2014 | Heating & Cooling
Capillary tube
You can determine this by taking a numbered drill bit index and inserting the proper size diameter but end of the bit into the cap tube. You can then mic the butt end or cross reference to chart giving size of numbered drill bits. The length is also very important when sizing, cap tubes must be as close to exact length as possible. Also cap tubes must be scored with 3 corner file and broken off so as not to alter inside diameter.
Or you could use a cap tube chart. Try www.supco.com
Apply Freon type, compressor HP, temp range of unit, number of feeds.
Aug 24, 2013 | KitchenAid Refrigerators
What are the regular dimensions of a sofa table?
Sofa tables vary in . They tend to be 48 to 60 inches in length and 18 to 20 inches high.
May 29, 2012 | Furniture
Vt200 wine cooler needs a new capillary tube. Repairman needs to know the diameter and length. The diameter will be some degreenof a 100th of an inch.
Hi
The capilliary can be sized from the outside diameter, the repairman should have a guage to measure it this gives him the internal size from the outside diameter, the length only takes a tape rule, these are normally set to plus or minus 1 inch, so not too critical
Hope this helps
Gordon
Apr 20, 2011 | VinoTemp VT200
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
Ac capillary tubes
Sounds like you have a clogged cap tube. Yes they should both be sweating, I would expect your low side pressure to be lower though unless it is real hot in the camper. You can replace the tube but make sure what goes in is the same diameter and length because that is all engineered for proper metering into the evaporator.
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
I installed a dual split ac system an code ch 33 comes up on both units does this mean its low on charge? i put in the recommended freon
Jun 09, 2008 | LG Heating & Cooling
2 ton sanyo suction pressure erratic
Your suction pressure is erratic, your max. pressure is to much high. You did not measure your unit current reading liquid line press. to complete the data. But the problem of your unit is not the compressor its the system. Try to reprocess the system flush the unit with nitrogen, isolate the capillary tube and flush it with nitrogen to insure that no restriction.
Jan 04, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Heating & Cooling Logo
27 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
