Question about Sony Televison & Video
My sony vravia 42inc internet tv isnt opening... yesterday there were thunderstrom hardly.... after that my tv is blinking red light 3 times
    Habit-Forming:
  • 145 Answers
Most likely as internal Fuse is blown. This can happen when static electricity builds up to high levels.
The Fuse itself is quite cheap, but you have to dismantel the rear cover of the TV to get to it. Try looking up a diagram for the mainboard for you TV model to find the location of the fuse.
The 3 time red blink is an error indicator. What it precisely means, should be listed in your manufactorer manual, if not try looking it up online for your TV make and model.
Posted on Mar 30, 2015
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Red light blinks 3 times but tv would not come on
The lamp door isnt attached properly or the lamp door switch isnt working.
Sep 14, 2011 | Sony KF42E200 TV
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I turn the tv on the green light blinks 5 times and the red light blink 6 times
this isn't a solution, I have the same issue. Mine started doing the 6 red blinks yesterday. How do I fix it? I've changed the bulb before...
Jun 18, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv model kdf 50e2000 shuts off and red light blinks 3 times.
You need to open up set and clean out all fans of dust or the new bulb isnt being cooled, or the color lcd isnt being cooled shutting TV off.
Apr 17, 2010 | Sony KDF-E502000 50" HDTV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Jul 10, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
