Question about Coffee Makers & Espresso Machines
Why is the machine leaking water from underneath and no water is coming out of the spouts?
    Habit-Forming:
  • 145 Answers
A plastic gasket needs to be changed..
Posted on Mar 30, 2015
Water leaking under the machine
Take a look at the little spout area that pours into the water tray. It can get clogged with coffee grounds. This was our solution with one machine. But with another, the water was actually leaking out the back and was the result of a dying boiler assembly.
Dec 12, 2012 | Saeco Vienna Plus Espresso Machine
Hi, I have a Asko W6221 washing machine. It is about 6 years old. Just recently it has started to leak water/washing detergent down the front of the machine, from the gap that is located underneath the...
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Aug 21, 2008 | Asko Washing Machines
Jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Rick
Nov 29, 2011 | Jura Capresso Impressa E9 Espresso Machine...
Water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Jun 04, 2010 | Danby DWM99W Top Load Washer
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
My admiral leaks as soon as the water turns on, it appears to be coming out of the housing unit for the hoses rather then the tub or the hoses.
There are a few places that a washer could be leaking:
1) the water valve itself, it may be cracked (most are plastic), or the hose connecting it to the spout may be loose.
2) the hose from the water valve to the spout (as above) could be loose from spout or water valve. It also may be cracked or have a cut in it from wear on other parts.
3) the spout may be damaged or loose from the back plate making it misaligned so the water spills over the side of the tub.
4) the washtub may be missing a spring that keeps it centered in the machine causing the fill spout to spray water over the side of the washtub.
5) There may be a leak in the tub, pump, hoses for the pump (not likely since when it leaks)
That's all that there is to leak when it does not leak all the time. (if it were all the time you could throw the supply hoses and valves in the mix.
Hope that helps
Oct 31, 2009 | Admiral AW22 Top Load Washer
Washing machine leaks water as tank is filling up.
Hi
If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Kenmore Washing Machines
Leaks water when filling up.
If the washer is leaking only during the fill and not all the time, the problem is most likely caused by a faulty air gap device, a leaking water inlet valve, or the tube. The air gap is a small device that keeps the washwater from being siphoned into the household water supply. It is usually located mid-way or at the end of the black hose that comes from the water inlet valve. Usually it is made of transluscent plastic. Look for leaks or cracks.
The tube is a rubber tube that runs between either the water inlet valve and either the air gap or the inlet spout. Check for leaks.
The water inlet spout - most washers have a plastic spout near the top of the main clothes tub that directs the flow of water into the tub. If the spout cracks or breaks free from it's mounting, it can cause leaks.
These are the things to look for if the washer is only leaking during fill. Hope this helps and best wishes.
Jul 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Leaking Machine from underneath
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 14, 2008 | Baumatic BTWM4 Front Load Washer
Coffee Makers & Espresso Machines Logo
71 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
