Question about Kitchen Ranges
The light and extractor fan don't work. I think they blew a fuse. How do I replace the fuse?
    Habit-Forming:
  • 145 Answers
Locate Fuse by looking up for diagram for the Make and Model of the product you are searching a solution for.
Posted on Mar 30, 2015
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Lights and fan simply won't work, how do fix it?
if it is a fuse your fuse box will be located under hood and sometimes you may also have two fuse boxes , one under hood in a black box in plan view that says fuse and relays. remove the cover and look under the lid. you will find descriptions and placement labels under cap. find your fan and lighting fuse if blown replace with recommended fuse. same goes for other fuse box under dash or located on driver side or passenger side of dash in between door and dash. must open door to view fuse box.
May 21, 2015 | Cars & Trucks
Every winter water drips from my bathroom ceiling mounted extractor fan, worse when there is bad condensation. The vent goes straight up and up through the loft space and out of the roof, there appears to...
condensation is created by 2 exteme temperature change.
looks like the loft space is colder than the rest of the house.
first make sure there is not blockage in the vent. then warp the vent with fiberglass as much as you can. it doesn't matter what R value the fiberglass is. just enough to cut the temperture change.
you still going to need a exhust fan in the bathroom.
Oct 31, 2008 | Hampton Bay 24002 Ceiling Fan
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Kitchen Ranges
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
461 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
