Printer leaves black band on label and does not printthe letters in this area
  • Office Equip... Master
  • 6,161 Answers
I would check the fuser black image unit or transfer belt make model would help
Posted on Jun 02, 2015
2 Suggested Answers
  • 81 Answers
SOURCE: problem with b-472 after printer sets for a period
Have you cleaned the printhead recently? residual label glue and ribbon debris can build up on the printhead. It's recommended that the printhead is cleaned everytime thr ribbon is replaced
Posted on Oct 13, 2009
Black ribbon is not back feeding same amount/speed as label, leaving black smudge at beginning of label
This is due to the quality of the ribbon.
When the paper moves back, since the head is not raised, the paper rubs on the ribbon en is the cause of the black smudge. Use correct Ribbon
Jan 08, 2011 | Toshiba TEC BSX5 Thermal Label Printer
Gaps in barcode with Zebra S4M
By gaps, do you mean a "void" area ? Over time, the elements on the printhead will wear down and finally they won't transfer heat to the ribbon. This causes a gap or void area. Usually the elements go out one or two at a time. If the area that is worn out is supposed to be printing bars for the barcode, this will cause the scanning problem you are experiencing.
The best way to see if elements are worn out is to design a label that has a thick solid black line across the label or a solid black box. You will see white vertical lines in the areas where elements are worn out. Another method would be to use the widest and longest label you have and print a 'pause" test label. This is done by turning off the printer, pressing and holding on the PAUSE key while turning on the printer. Hold the pause key for 10-15 seconds and when the printer is done with it's power on self test, it will start printing out a test pattern label which includes a nice black area where you can look for the white vertical lines.
Hope that helps !
Mar 30, 2010 | Zebra S4M Thermal Label Printer
Zebra Xi III
yes .. the print heads can be calibrated to compensate for cold labels or you could just warm them up .. if they are really cold then it takes longer to expose the image .. if you dont compensate for that then the letters will not be fully developed (grey)
Nov 23, 2009 | Zebra 170Xi II Thermal Printer
Brother P Touch 2450 labels print white on black
You can change it by pressing and holding the function (or special) button while you touch the button with a black background.
Jan 05, 2009 | Brother P-Touch 1180 Label Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
Poor Quality (black line)
Check the temperature settings. If all of the text and barcode is clear and not fuzzy, check the platten roller for low areas, cuts, or other deformity.
Dec 12, 2007 | Zebra 170XiIIIPlus Thermal Label Printer
Casio HR-100TE
The problem of your unit is its printer. Probably the gears has misaligned. Only an authorized technician can align the printer of that unit, because it is a bit difficult to align the gears.
Try to contact the nearest service center of casio in your area.
Oct 13, 2007 | Casio HR-100TEPlus Calculator
27 people viewed this question
jasbo
jasbo
