Question about Siemens Dryers
Siemens heat pump condenser dryer not getting warm.
  • 2,210 Answers
Did you not get left an owners manual? If not go online to Siemens and download one. Who was the installer, ask them?
You don't give the system details so we can't trace anything for you.
Posted on Mar 30, 2015
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
Dado
Jul 02, 2015 | Bosch Dryers
To continue from my last Question, to do with HVAC Evaporator/Condenser Cycles, how often should the System go into Heat Standby, Heat Defrost, and Heat Modes? What are Heat Standby and Heat Defrost?
In this type of system (heat pump), the evap and condenser swap functions by means of a reversing valve, according to the mode selected. Evaps throw off cool air, condensers, warm air. In heat mode, the condenser is the indoor coil and it throws off heat from the outside air. Vice versa for the cooling mode. Heat Standby would be whenever the temperature thermistor has reached set point by the user and shuts down the system. Heat defrost is the cycle that reverses refrigerant flow and defrosts the outdoor coil by sending warm refrigerant liquid to that coil. In heat mode, the outdoor coil builds frost and ice on its surface.
Feb 05, 2015 | Refrigerators
When dryer is on there is a smell of catfood/fish while clothes are drying.
Move dryer and look for cat food/fish under or behind. The heat may be activation the order.
Jan 14, 2015 | Siemens WT46W568GB Condenser Tumble Dryer,...
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
Dado
Aug 10, 2014 | Zanussi Dryers
The difference between the heat pump and condenser
Well...they are kinda the same. The condenser is where the refrigerant is condensed from a gas to a liquid. When in AC mode this happens outside at the AC unit. (You ever put your hand over a running AC unit in the summer? Feels warm!). When in Heat Pump mode the process is reversed. Instead of condensing the gas to liquid outside (which creates heat) the condensing happens inside and helps warm the building up (with the help of the fan of course). So essential the condenser is where the gas is condensed into a liquid, which creates heat. A heat pump can reverse the direction of the flow and cause this condensing to happen either outside or inside.
This is a very watered down version of what happens but I hope this is sufficient for what you are asking.
Jun 29, 2014 | Goodman Heating & Cooling
My Siemens IQ-700 tumble dryer not heating during drying cycle. It is a WT46W572DN/16 condenser model. How can I reset it? Is there a high heat emergency switch somewhere in it? Any source maybe for a...
Ok there could be several things preventing it from heating, here is a list gas valves, heat limit switches, bad thermostat, bad sensor. Time to open it up and get to testing. Sorry but this not one with a simple answer..
Apr 18, 2014 | Siemens Dryers
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Kenmore Gas Dryer-70 Series is condensating and doesn't heat up
reck vent starting behind dryer then to outside try drying a load with vent disconnected may get warm but will prove or disprove vent problem..water is from clothes and is recondenseing because there is no escape to outside
Jul 02, 2008 | Kenmore 63942 Dryer
Splendid washer and condensing dryer combo
Since the clothes ARE getting hot, it's not the tripped breaker(s) mentioned in Solution #2, because these would cut off power to the heating element(s).
Since it's a Condensing dryer, it can't be an obstructed exhaust hose, either (as there is no dryer exhaust).
Remove the lint filter(s). Holding it over a sink, see if water flows through it. The waxes in "dryer sheets" clog lint filters and, even though invisible to the eye, can totally obstruct the air flow and stop a dryer from drying. Wash it with soap and water.
Question: Does your dryer have a small drain hose leading out the back and going down a drain? If it's clogged, the dryer can't remove any more moisture. If there's no drain, then you have an internal "catch tank" to collect the water evaporated out of the clothes. It's supposed to be emptied after every load. Empty it.
If that's not the problem, I suspect your condenser is not working (removing moisture from the hot stream of air blowing through the wet clothes. This could be because: (1) It's clogged - Take out the boxy thing (technically called a heat exchanger) made of thin aluminum "fins" or tubes, and wash it off in the sink. or (2) The little fan that cools the condenser isn't running. In this case you'll need to call a technician. Good luck
Dec 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
163 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Mike
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
