Question about Dryers
I am trying to clean my light-vent-heater in my bathroom ceiling. The manual said to take out the blower assembly and heater assembly to clean with vacuum but it did not show how. I am hoping someone can help me for it is making noise when I turn on the vent to air but works just fine when I turn on the heat. Any suggestions?
  • 2,210 Answers
Get a good DIYer or local electrician to have a quick look. As it involves electricity only use trained help.
Posted on Mar 30, 2015
How to vent exhaust outside
bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg9dbdeaa6-0b81-4926-ab21-2206dc8f6420.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Oct 21, 2013 | GE Spacemaker JVM1540 Microwave Oven
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Aug 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Black soot every were how do i clean it and what with
Well, Boat Bob, you can clean the soot off by using a Shop Vac with a brush attachment on the hose. That will take off the biggest portion of it. Then you can clean the remainder of the outside with a damp cloth, but be sure to dry the cabinet afterward. Remove the screws the are holding the face of the of the cabinet on and proceed to clean all of the interior of the heater cabinet fire, with the Shop Vac , being sure to vacuum the burner(s) thoroughly, as well as the pilot assembly and all the mechanical 's. What soot isn't removed with shop vac, should be removed with a DRY cloth. Then use a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the pilot and all around the pilot assembly.
For the remaining soot on walls, ceilings, furniture, etc. Gently vacuuming is the best way to remove the lion' share of the soot. Then, if necessary, the walls and ceiling can be washed with a diluted solution of Simple Green and water. Clean small areas at a time.
After that, you need to turn your attention, as to why the heater sooted? Several things come to mind ... No annual professional cleaning and service; Incomplete combustion; Vent pipe partially obstructed; Low gas pressure; Clogged burner(s), Obstructed air intake.
If you'd like further information, here is a link to your Owners Manual, which will help you to Troubleshoot the heater. http://www.empirecomfort.com/EMPIRECOMFORT/pdf2009/manuals/12433-10-0109DV.pdf
Hope this helped you to answer your questions.
Mar 24, 2011 | Empire DV-215 Direct Vent Natural Gas...
Our new bathroom fan is not clearing the room the ceiling is wet and the paint peeling the fan is model #FV-LP003
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
Jan 23, 2010 | Panasonic WhisperFit-Lite Low Profile...
Have a Goodman GMT070-3B which the vent motor seems to be sticking. I took apart and cleaned the brushes and reassembled. The furnace will come on only after what seems like the vent motor comes up to...
The whole assembly must be replaced.
The sequence of operation is -
Combustion fan purges the heat exchanger. A pressure switch verifies combustion air fan is running. Usually a 30-45 second purge before the hot surface ignitor glows, or the spark ignition starts.
Gas valve opens after 10-15 seconds and main burners light. Control board monitors for flame and shuts gas valve after 2-3 seconds if main burner does not light.
If burner does not light, some boards repeat this for 3 tries, then locks out and is reset by cycling power.
Air blower comes on after another 30-45 seconds after main burner ignition.
Times may vary based on the specific controller board. A flow chart and timing sequence should be located somewhere on the unit, usually in the fan compartment.
Dec 16, 2009 | Goodman GMS90703BXA Heater
Need owners/instruction manual for Desa blower model # PP100
link to manual: http://www.desatech.com/manuals/Vent-Free%20Heaters/HDR16PT.pdf
Oct 26, 2009 | Desa International Blower Glow Warm Wall...
How do you access the light on a broan fan/heater/light? This is a ceiling unit in a bathroom. It is a vent fan/heater/light combo.
Gently pull down, work it down slowly these tend to get dry over time and crack, If you do not see any exposed screws it is the basic pull down type. Not to insult your knowledge but make sure the fan is not on when you do this because the blades will be exposed.
Oct 09, 2009 | Dryers
My blower wheel on our nutone 9093 vent fan keeps
Buy a tube of Household Goop, and put some on the front and back of the hole the motor shaft goes through and glue the wheel in place. Make a little 'pile' or filet around the shaft/wheel joint. Let it dry a couple of hours.Goop is extremely handy, sticks like glue should, stays flexible, is cheap, etc.
Oct 03, 2009 | Heating & Cooling
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
Dryers Logo
71 people viewed this question
Top Dryers Experts
