Question about Garden
I need a diagram of how the fuel lines are set up on a 12 inche GMC CHAINSAW
THIS SAW HAS DONE ONLY ONE HOURS WORK AND WAS PUT AWAY AND LEFT , WHEN HE WANTED TO USE IT THE HOSES HAD ALL CRUMMBLED SO I HAVE NO IDEA WHERE THEY GO I HAVE TRIED ALL COMBINATIONS BUT IT WILL ONLY START IF YOU INJECT PETROL DIRECTLY INTO THE CABURETTOR
  • 2,210 Answers
There are a lot of these about, is there no online handbook or dealer you could call or visit to look at another one? Try gmctools.com, its the main company website.
Posted on Mar 30, 2015
Fuel line diagram
Here is the way to hook up the fuel lines
fuel-line-diagram-0snlkc2idhfslary3a2ev3kp-4-0.jpg Note: I put it together outside of the saw so you could see how it is hooked up. Fuel filter/pickup >>to>> Inlet on carb >>to>> Outlet of carb >>to>> to inlet on Primer bulb(shorter post) >>to>> Outlet of primer(longer post) >>to>>Fuel tank (usually has a retainer in tank to prevent fuel line from coming out.)
Jan 11, 2016 | Poulan P3314 14-Inch 33cc 2-Cycle...
I have a 2011 husqvarna 345 xtorq only done 2 hours work .i got spark , cleaned out carb new plug still wont start or even fire any ideas plz
did you check for spark? you need air fuel and spark for engine to operate. check all of these then if it still wont start check the ground wire from coil to switch
Aug 14, 2014 | Garden
Fuel line diagram for mcculloch chainsaw
Refer to your service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 07, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Petrol leaking when turned up side down,Ryobi Chainsaw
Upside down is not a usual sawing position--only upright, or turned to the left or right side is recommended. If you need to undercut something, keep the saw upright and cut with top side of the chain/bar.This can lead to kick-back if the tip comes free of the log/branch, so you need to control the saw carefully. That's also why there is a chain brake on all newer saws. The leaking may be occurring where the fuel lines pass through the wall of the fuel tank. Hope this helps!
May 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Fuel lines
The main fuel line goes to the bottom of the tank. The other, sometimes larger line goes to the primer bulb. This line goes just inside the tank, not more than 1"(inch).
May 20, 2009 | Poulan Pro Chain Saw 46cc 20"
Need manuel to show how gas lines are run to carb. & pump bulb
HOW TO CHANGE FUEL LINE ON McCULL0UGH 2014 CHAIN SAWS.
I have successfully changed the input fuel line by purchasing Tygon tubing from a local lawn equipment dealer. I did not see the box he cut this from, but the tubing I bought measures 0.190" outside diameter. I gave him a piece of the old tubing and he matched it up. A 18 inch piece cost me $1.19.
The routing of the fuel line involves three pieces, one piece from the fuel priming bulb to the carburator is 3 inches long, a piece from the fuel priming bulb to the gas tank is about 4 inches long and the piece from the fuel tank is about 7 inches long. The priming bulb sucks air and fuel from the carburator and dumps it back into the gas tank. Therefore, when you press this repeatedly, gasoline will eventually appear in the bulb when the gas line to the carburator is full of fuel. The bulb may not completely fill, there will always be a little air in the bulb.
The fuel line in has a filter on the end within the fuel tank. If you find this has broken off, as I did, you have to turn the tank upside down and shake the filter and any pieces of broken fuel line out of the tank.
Replacing the fuel lines within the carburator compartment is easy if you remove the carburator first. To work on this you must remove the two screws holding the carburator to the engine. You may need to use a small screw Torx driver, although on my chainsaw, there was also a long straight slot on the head. The line from the priming pump to the carburator goes to the left hand line on the carburetor (as viewing from the top with the blade extending away from you. The input line will go onto the right line on the carburator.
The two lines into the fuel tank are located in the middle of the tank left to right and one about 1/2" above the other. The upper hole is for the fuel intake line. The fuel line passes through this hole and a second hole visible within the tank fill hole.
This was the trickiest hose to replace. How I did it was to use a piece of #12 copper electrical wire stripped out of its insulation. This was fed through the 7-inch Tygon tubing piece until it emerged from the far end. I also found it necessary to put a bull nose end on the Tygon tubing in order to get it to feed into the tank hole visible from the tank fill hole. Why? I don't know, but after 20 minutes of trying to feed the hose (both naked and with the electrical wire inside) into that second hole, I gave it a bull nose on the tubing by careful cutting with sharp scissors and using a sanding block. Perhaps McCullough has a special tool to do this, but a call to their 800 number could not get a knowlegible answer from the parts person.
After the Tygon tubing shows up in the tank fill hole, I pulled it further with needle nose pliers and was able to pull the copper wire back out of the tubing. I then cut the bull nose lead I put on the Tygon tube and installed the filter onto it. I found that a little oil on the nozzle and the carburator lines makes the tubing easier to slip on. The stuff the filter and Tygon tubing back into the tank fill hole and towards the front end of the tank so that it drops into the bottom portion of the tank. After attaching the intake line to the carburator, use the needle nose pliers to pull excess line into the tank.
Reassemble the carburator to the engine and you'll be good for another 10 years of happy chainsawing!
Apr 01, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
