Question about Asko T741 Dryers
Hi. iam taked out wire from the Power conection and i cant take them like before can you give me a picture how the power connection look
  • 2,210 Answers
If you have no electrical knowledge do not go any further!. Get trained help before you are in big trouble.
Posted on Mar 30, 2015
Trying to replace the power cord - but I can't remember which wire goes where... white & black wires have same type of connection, and not sure where the ground goes.
Need more information to give exact answer.
If it is 120 volt, then white is neutral and black is the hot wire.
The ground wire is connected to the metal frame, should be a green screw or a connection lug just for this ground wire.
Post a picture of the wires you are trying to connect and a picture of the connection terminal on the ac unit and I can give you an exact answer.
Apr 11, 2015 | Frigidaire Heating & Cooling
Speedo meter on the fiesta 2007 drops intermittently and comes back on. radio volume drops and car loses power slightly
Sounds like your alternator is trying to die out on you. Take it to the dealer to check the voltage that it's reading whenever the cars running, and when its not. Also, check the connector wires that connect to the alternator for bad spots. Or to see if the connectors are dirty. Hope this helps, James Booth
May 17, 2011 | Ford Focus Cars & Trucks
Hi,made connection by use of HDMI cable from ps3 to tv with no problem.But now i wont to conect to tv which doesnt have aHDMI point.So i have got a SCART Lead which conect to ps3 to tv and i have an AV...
turn on your ps3 (with your tv also on) and hear the ps3 start power beep. after you hear this normal beep, press and hold the power button for 5 seconds till you hear a beep then let go of the button.
This will reset the outputs and resolution to defaults and you should get your display again, if you don't then the ps3 has a fault.
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
Power jack is broke. want to connect to battery pins off motherboard. need pin assignments. i found them for the power jack but cant find for battery connection.
it is nearly just as easy to cut the conection of the power cord and weld it strait to the board where the conection was, or use a volt meter and trace the conections back to some where more stable, conecting strait to battery will or might do damage and the laptop will think it is always running of the battery. and or also could over charge the battery because you are bypassing the switch that stops it. hope this helps a bit.
Dec 02, 2009 | Dell Inspiron 6000 Notebook
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
Cant conect to internet using wirles with Windows Vista
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck.
Aug 30, 2009 | Microsoft Windows Vista Home Premium with...
Van wont start or turn over. (battery has lots of power)
Possibly a dirty or loose battery terminal. If they are okay and starter won't click, give the small wire on the starter motor solenoid a wiggle. It could be a bad conection.
Aug 16, 2009 | 2001 Buick Regal
Won't power up
Hi Billy,
Check the capacitors at the top right of the power supply, are any of them swollen? If so replace them & power it up. I have a had a few of these power supplies going dead & have found a few other problems with them as well as the capacitors. Usually I just replace the power board as it saves a lot of time investigating further trouble. The wiring I believe is manufacturing oversight & will not have too much bearing on your problem.
Aug 03, 2009 | Televison & Video
How can i connect my nokia 5130 c 2 to my pc
Iam unable to conect my 5130c 2 to pc through data cable as the driver cd not supplied with the pack
Jun 22, 2009 | Nokia 5130 Cellular Phone
Asko T741 Dryers Logo
56 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
