Question about GW Security Professional 4 Channel 1t Hdd Installed H.264 Standalone Network Hdmi Cctv Dvr For Security Camera System - Iphone, Andriod Viewing. Hdmi & Vga. Windows Graphical Interface; Embedded Real-time Linux 2.6 Operation System. Preview, Record, Playback, Ba
Have an error message on screen sayng NO HDD???
It is set to record continuously and is now showing error NO HDD??
    Top Expert:
  • 6,702 Answers
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
Posted on Mar 30, 2015
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Problems recording on LG RHT49H HDD
There may be plenty of space in the HDD but you can only set a certain number of timers. Delete a less important timer setting to make room.
May 05, 2014 | Televison & Video
Came home to find HDD full and camera recording stopped with monitor saying No Signal. Checked and HDD is formatted though overwrite doesn't seem to be working yet the box for it is ticked. All cameras...
Adjust your settings to continue recording when the hard drive gets full. If 'Overwrite when full' is enabled, the system should start overwriting the oldest data when new data is recorded. Note that these are two different settings: 1) Continue recording (or do not stop recording) when disk is full and 2) Overwrite when full is enabled.
Hope this helps.
Oct 10, 2013 | Televison & Video
"ATA Initialization...ERROR" Response
Check to see if the BIOS has ATA, SATA, Legacy setting for the HDD. Try all settings for the HDD. You'll need to have your OS CD/DVD in the optical drive as well so you can begin installation fo the OS.
If that doesn't work, Sony's tech support is pretty good if you can get them to talk to you. I've had issues w/ out of warranty laptops and PCs in the past.
Good luck.
Jul 16, 2017 | Sony RDR-HX900 DVD Recorder
Hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
GW Security Professional 4 Channel 1t Hdd Installed H.264 Standalone Network Hdmi Cctv Dvr For Security Camera System - Iphone, Andriod Viewing. Hdmi & Vga. Windows Graphical Interface; Embedded Real-time Linux 2.6 Operation System. Preview, Record, Playback, Ba Logo
233 people viewed this question
Top GW Security Cameras Experts
Are you a GW Security Camera Expert? Answer questions, earn points and help others
