Question about Chevrolet 2003 Chevrolet Blazer LS
Where is fuse located at for instrument panel on 2003 Chevy Blazer LS
  • Chevrolet Master
  • 11,718 Answers
Fuse Block - I/P- instrument panel
At the left side of the I/P, near the left door jamb switch. there are four fuse's that supply power to the I/P fuse #3 cruise 10amp - fuse #4 Gauges 10amp - fuse #11 CLSTR 10amp - fuse #19 RDOBATT 15amp ! Hi Dave hope this helps , but I have to ask what trouble are you having ? Gauges not working ? GM had problems with instrument clusters 03 to 06 , had bad stepper motors that controlled the gauges !
There are f
How to repair GM Instrument Cluster Speedometer Gauge Stepper
Posted on Mar 30, 2015
emissionwiz
  • 76109 Answers
SOURCE: no instrument panel lights on a 2003 chevy monte carlo
Most likely this is caused by either the dimmer being turned off (happens all the time on my Corvette) or the dimmer is defective.
Posted on Nov 30, 2008
Molson02536
  • 3854 Answers
SOURCE: where are the air conditioning fuses 97 chevy blazer located
97 only had one fuse panel in the dash on the drivers side. There is/was a junction block for power that had/has fusible links on the driver side fender too.  a) 20a pwr accy
b) 30a pwr wdo
1) 20a stop/haz
2) 20a horn/dm
3) 20a tl/ctsy
4) 20a guages
5) 20a Eng-1
6) 25a htr/ac
7)25a pwr aux
8) 30a rr defog
9) 20a ecm/batt
10) 20a emc/ign
11) 20a radio
12) not used
13) 10a rdo/batt
14) 10a illum
15) 10a drl
16) 15a turn/back up
17) 25a wiper
18) 20a brake
19) 20a 4wd
20) 10a crank
21) 20a fog
22) 10a air bag
23) 10a trans
24) 10a prndl
The A/C relay is in the glove box behind a panel that indicate relay. There are three relays in there, the middle relay is the fuel pump and one of the out side relay is for the A/C compressor and the other is for the third brake light. Just can not remember which out side relay is the A/C so just swap the out side relays with one another. Good luck and hope this helps. Keep me posted.
Posted on Jun 25, 2009
SOURCE: instrument panel cluster gauges and odometer has stopped working
I had all my analog instrument panel gauges stop working after they did the state emissions test. I found the proper fuse in the fuse block located under the hood. Simply unplugged the fuse, noticed it was still good, and plugged the same fuse (10A) back in and all the gauges started working again. Guess it needed a reset atfer they plugged in for the emissions.
Posted on Aug 14, 2009
  • 4 Answers
SOURCE: fuse panel location and diagram 2000 chevy malibu
if the car is built like monte carlo for 2000 there are 2 fuse panels inside. one on the driver side when you open door and theres one the passenger side when you open the door there are panels on both sides of the dash that pull off. and then of course there are the fuse blocks under the hood. by the battery.
Posted on Sep 17, 2009
SOURCE: where is the instrument panel fuse block located?
under the glove box, you'll set a panel with 2 plastic pressure pins. using a pair of pliers, just pull from the center and remove both of them. the entire panel will be free, and the fuse block is on the far right side, (closest to the passenger door) you'll need a good light and small hands....the engineers did NOT give you a lot of room in there!
Posted on Apr 24, 2010
Where is the fuse for my interio lights in my 1999 chevy venture?
Instrument panel fuse block is located on the passenger's side of the instrument panel.
May 21, 2014 | 2003 Chevrolet Venture Passanger
Purchased used 2011 chevy malibu ls and was trying to turn radio on, there was nothing, what should I try
Start by checking the 10A RADIO BATTERY FUSE in the righ instrument panel fuse block
Feb 18, 2014 | 2003 Chevrolet Malibu
Check engine light not lighting up
its probably the bulb,or its been removed,or a bad connection at the back of the instrument cluster
Feb 28, 2013 | 2000 Chevrolet Blazer
Where is fuse box located ?
For Chevy impala instrument panel fuse box location and diagram.Click the link below :----http://technoanswers.blogspot.in/2012/02/where-is-fuse-box-located-on-2003.html
-----------And for chevy impala under hood fuse box location and its diagram click the link below :----http://technoanswers.blogspot.in/2012/02/under-hood-fuse-box-diagram-for-2003.html
----------Check both the fuse box diagrams for better understanding.Thanks.
Feb 05, 2012 | 2003 Chevrolet Impala
2003 chevy blazer ls cruise not working
possible causes check for a blown fuse a vacuum line disconnected, cracked or broken, check the electrical connection at the cruise control actuator
Nov 22, 2011 | 2003 Chevrolet Blazer
Location of heated seats fuse 2003 chevy impala ls
the fuse for the seats should be located behind the fuse panel on the drivers side dash end. if not driver then passenger
Nov 06, 2011 | 2003 Chevrolet Impala
91 Chevy K5 Blazer turn signal flasher
located under the instrument panel to the left of the steering column. The fuse block should be visible from underneath the steering column, near the pedal bracket.
Some models may use an underhood fuse/relay panel
If the panel is not visible, check for a removable compartment door or trim panel which may used on later models to hide the block. This panel is usually located on the left end of the instrument panel.
The convenience center is located just below the instrument panel on the drivers side. It contains individual relays such as the seat belt and ignition key alarm, and flasher.
On newer model vehicles there is an underhood fuse/relay center contains both mini and maxi fuses, as well as some relays.
Replacement The turn signal and hazard flasher units are usually located in the convenience center located just below the instrument panel on the drivers side. Replace the flasher by unplugging the old one and plugging in the new one. Confirm proper flasher operation.
Nov 03, 2009 | 1991 Chevrolet S-10 Blazer
Chevrolet 2003 Chevrolet Blazer LS Logo
422 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
CrisO
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
