Question about Brother DCP-350C InkJet Printer
Says no cartridge black. Ifollow the instructions and put in a new black but exclamation mark light stays on and window still says no cartridge and proceeds with instructions to replace cartridge.
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
My HP photosmart 7510 does not recognize the presence of any color cartridges. I use only HP 564 cartridges. It prints only black. What can I do with it?
Check this link for ink cartridge problems. The part on "older generation cartridges" is very interesting. It is located on page 39 of the manual (page 40 of the pdf).
http://h10032.www1.hp.com/ctg/Manual/c03011756.pdf
Jan 06, 2015 | HP Photosmart 7510 e-All-in-One Printer
Laptop screen is dark and says video controller is out
The exclamation mark means the driver is not working properly. Try removing the driver, reboot and windows will use a generic driver. If the display is working, download and install the correct driver.
Dec 05, 2012 | Toshiba SATELLITE A55S1064 COMPATIBLE...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Hp officejet v40 printer
I'm not sure if this will help but I aligned my cartridge's 5 times then the red exclamation point light stopped to do this hit the setup key #5 (maintenance) then hit # 2 follow instructions... to print full menu settings ..setup #1 then # 4 follow instructions
Jun 15, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
May 21, 2009 | Samsung ML-2510 Laser Printer
Red error light stays on says needs black ink but i just put a new one in
the main issue here is that your printer don't recognize your new black cartridge.
try shutdown your printer and on it again or long press on your power button ..
and your also to open close your main door of your printer..
so that it will recognize the full black cartridge.
May 18, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Data light and Cartridge light stays on
Clean off cartridge contacts on printer carriage where carts sit and contacts on cartridges-if they sit for long periods of time they clog up.
you will probably need new cartridge{s}
start with black and go from there.
we use alcohol.
Apr 02, 2008 | HP DesignJet 450c InkJet Printer
New cartridge problem
Machine needs both cartridges working to work
Nov 26, 2007 | HP PSC 1315 All-In-One InkJet Printer
Flashing exclamation mark
Yea this just happened to me today. Fortunately, all I needed is to clean the color cartridge. Grab a towel and wipe the bottom of the color cartridge throughly. After, put it back in and it should work.
Clean it good, make sure it's definitely cleaned. I had black smudges on mine and had to take it all off b4 it worked again.
Nov 19, 2007 | HP PSC 1610 All-In-One InkJet Printer
Brother DCP-350C InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
