Question about Pentax Optio S10 Digital Camera
My cameras digital screen is black, and only takes black pictures.....i can not recall the camera being dropped or damaged?
jackboy
  • 2985 Answers
SOURCE: Lens error
If it is a new[ish] purchase send it back via the seller. It may be an issue with the particular model. Get onto Pentax Tech support Team- See what happens- if it is an issue then a replacement free or at moderate cost may be available. If the camera is older -there will be no economic repair option.
Posted on Jun 21, 2007
jackboy
  • 2985 Answers
SOURCE: Black Screen
Is there no image at all?
Or if you look carefully can you see fient images on the screen.
If you can then the back light has failed orv a oconnector has come loose.
If this is so - then try squeezing the camera body at the base of the screen- or with it switched off and the batteries out give it a sharp slap into your other hand. This may restore contacts.
If no luck - then by all means checkout a repair price with Pentax.
But it may be worth while investing in a new camera with better spec.
Posted on Dec 21, 2007
SOURCE: No view on the screen
I was lucky to have this happened on th efirst month. They replaced it with another camera that is eating batteries like crazy.
Posted on Feb 02, 2008
SOURCE: pentax optio S50 Digital Camera problems.
my touch screen display does not work
Posted on Aug 08, 2008
VOTIT
  • 2071 Answers
SOURCE: MY OPTIO DIGITAL CAMERA IS NOT STARTED
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time. Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it. Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in ?no heat? setting, or sucking the gaps with a vacuum (careful with this one). Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes. Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens. Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error. Hopes this may help you; Regards, VOTIT
Posted on Oct 06, 2008
I dropper my camera and the screen is black now
Sounds like your camera was damaged in the drop. Attempting to fix the damage is well beyond "do it yourself". Take it to be repaired or replace it.
Nov 13, 2015 | Sony Cameras
Camera was dropped and now pictures take but are completely black
As has been explained many times, dropping a camera damages it. Damaged cameras do not work. They are what is technically known as 'broken'. You will have to get it repaired.
Sep 20, 2017 | Panasonic Lumix DMC-LZ7 Digital Camera
Black screen on IXUS 500
Found solutions on your wep-page from others with the same problem.
Thank you
Sep 12, 2009 | Canon PowerShot S500 IXUS 500 Digital...
I dropped camera or something happend-please help asap.
Your display screen is damaged. Just get it replaced at nearby camera technician. It should be all right.
Sep 29, 2017 | Kodak EasyShare One Digital Camera
My powershot A70 will not take a picture
It is a common problem with this camera. I had to send my back to have it fixed. Luckly it was under warrnity. Sorry I can not recall what they said was wrong, but talking to others, it seems to be common.
Oct 30, 2008 | Canon PowerShot A70 Digital Camera
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on anything....it's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Dropped camera- screen is white
OK. I think you should replaced damaged camera LCD. And you should take care of camera lens.
KAT
thu241@gmail.com
Myitkyina, Myanmar
Jan 08, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Nixon coolpix L11
if the resulting images are the same, you have damaged the camera settings/controllers. see how they look on your computer.
if only the display on the camera is damaged, you should consider asking for a flat rate repair. most makers offer a price for major and minor repairs, and never charge beyond that.
good luck
mark
Nov 25, 2007 | Nikon Coolpix 5700 Digital Camera
Only half the image apears other half is black
well your sub-mirror is broken inside of the camera, i had the same problem, it just happens by itself after extended use of the camera, and it is not a means for recall by canon so you have to deal with it yourself.
this website can fix it for $130 and they will replace it with a metal piece so it doesn't happen again(original piece is weak plastic)
Oct 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Pentax Optio S10 Digital Camera Logo
50 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
