I need a spear part for champion c p w 1600 how do i find it
It is on the front of the washer wear the water comes throw the head in to the hose with the Pressure it has snapped in two
  • 14,397 Answers
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
What is a spear?
A spear is a pole weapon consisting of a shaft, usually of wood, with a pointed head. Spears can be divided into two broad categories: those designed for thrusting and those designed for throwing.
Aug 30, 2012 | Century Martial Arts
Washer flashes f 1 on the display window
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Kenmore Oasis HE 27082 Top Load Washer
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Headlight washer system leaks out all the fluid just sitting without using the pump button
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
Nov 20, 2010 | 2000 Mercedes-Benz S-Class
Leaking water
When your Maytag top load washing machine leaks water, you will need to check the following parts until you find where the leak is coming from.
The water valve: The first place you need to check is behind the washer. Check the two fill hoses and the water mixing valve.
Check for pinholes or cracks on the plastic body of water mixing valve.
Remove the front panel : The next thing you need to do, is to remove the front panel so you could see the tub and the hoses.
Set the washer on the regular cycle and turn it on so it could start filling.
Use a drop light and check all the hoses under the washer as the washer is filling.
Make sure to keep your hands away from any moving parts.
The pump : If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag washing machine to leak water.
The stem & seal : Another place that the washer could leak water from, is the stem & seal on the holding tank.
When washer leaks water from the stem & seal, the water will leak down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110.
Apr 19, 2010 | Maytag PAV2300 Top Load Washer
Code nd on maytag neptune
You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Wear gloves, as it's always a nasty stuff what comes out. ;) Reverse steps to assemble the pump back together. If you don't hear pump running after completing all the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
First Choice Appliance
Jan 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool duet washer throwing H the F code
f06 usually means problem in motor speed circuit either main control or motor control or possible wiring connections..FH is usually a problem with the flow meter left side under top has small hose from fill valve and one to dispenser...it's not reading water flow to machine a light tap may help confirm problem if doesn't help may need to change flow meter anyway small switch on small bd with wires will stick and not signal main bd there is water flow
Sep 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
Washer leaks on on the floor when using a large load setting.
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
