Error is test mode
SOURCE: insert sim
Hi have a repair shop, and you know it’s a very common problem on this model. 90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits. Don’t fiddle with your sin contact/ reader if no damage visible to the eye.
SOURCE: n70 nokia on boot 2second
if its nokia n70 mobile phone, just reset to factory setting, all problem will be solved
SOURCE: i have nokia 2680s network
nokia 2680s no network so change network Ic but notwork ic so network ic jamparing solution in picture
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
