Question about Thule Hullavator Kayak Carrier
Thule hullavator handle will not squeeze to pull down to vertical position it is stuck in unlock position.
Thule Hullavator 897XT will not squeeze to pull down to vertical position. Also key will not lock. Can you advise how do we fix as we cannot use hullavator.
    Sergeant:
  • 273 Answers
Retire it
Posted on Jun 22, 2016
Dyson Animal vertical portion won't lock into vertical position. However, all suction is going through the vertical portion...brush roller head isn't on at all.
Theres a part on the side that is free to move when u pull machine down for using it diverts suction.sometimes they get stuck pull handle right down to floor level turn machine over and check on the side at hinge part
Apr 15, 2017 | Dyson Vacuums
How do I set and release the brakes
On most walkers the handle you squeeze to make the brakes work will push down. If you push them down the brakes will lock on and pull up to unlock.
Sep 23, 2014 | Medline Guardian Luxe Rollator,White,Each"
How do I shut the engine off on an Ariens walk behind Lawn Mower?
Adjust the brake cable that leads from the handle to a full down position.
Jun 03, 2014 | Ariens Garden
Thule Hullavator arm does not automatically lift as other arm does....seems to be leaking fluid?
Hullivator lift cylinders are pneumatic, there is no fluid to leak. However, they do fail, and when they do, they do not provide lift. Despite what Thule says, the cylinders can be replaced. I have replaced 4 of them. Drill out the rivets holding the old cylinders in place. I bought new cylinders from LiftSupportDepot.com - they were very helpful and they charged a little less than $30 each for the cylinders. The first cylinders were 75 pound lifts. Those my sister found too light to provide all the lift she wanted. I have since installed 150 pound lifts (this will require a clamp). I cut off, and reused, the longer of the original Thule rivets where the shorter rivet formerly was, and used a 5/16ths 4" stainless bolt in place of the longer rivet. It will take a couple of tries and some prying to get all the holes lined up for that last bolt, under pressure, but in retrospect it will all seem to have been surprisingly easy. Good luck.
Jul 07, 2013 | Thule Hullavator Kayak Carrier
Brakes will not lock in parking position
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. This same adjustment technique applies when you pull the handles down in the park position and when you squeeze them to slow down. Hope this helps.
Nov 22, 2010 | Drive Medical Winnie Walker, Mimi Lite...
The handle on our Marcato Atlas 150 keeps getting stuck and is difficult to pull out for storage. Any ideas?
I opened the rollers to the widest setting (Zero), and placed a folded business card between the rollers. I then turned the dial down so the rollers were "pinching" the card, and while keeping tension on the dial to gently squeeze the card, I gently shook the handle for a few seconds and it came out!
Jan 12, 2010 | Atlas Translator Marcato Atlas 150 Handle...
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
How do I use a Blackburn Mountain air pump?
Dear Doug, to lock a hand pump onto the valve stem: 1.depending on valve type-loosen the valve lock for presta, twist off valve cap for schrader. 2.unlock the pumping handle from the pump so that you can actually "pump" the pump... 3. put the pump head on the valve of the tire, then pull up on the thumb tightening lever. This should squeeze toghether the internal rubber gasket of the pump, and lock on to your valve. 4. Begin pumping. 5. when desired pressure has been reached, push down on the thumb lever to unlock the pump. Remove it. Good Luck Fellow bicyclist!
Jan 18, 2009 | Blackburn Mountain Air Mountain Bike Pump...
Bissell Proheat Problem
Take the top part of the handle off, make sure that the rod in the handle is moving up and down when squeezing the trigger. The lower part of the handle has a valve that the handle rod pushes on, it make be stuck in the open position.
Jul 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Thule Hullavator Kayak Carrier Logo
743 people viewed this question
Top Thule Boating Experts
Tom Chichester
Richard Warren
Richard Warren
john cordey
john cordey
Are you a Thule Boating Expert? Answer questions, earn points and help others
